주요 콘텐츠로 건너뛰기
Motorola C350 Microphone Replacement
필요한 것
  1. Motorola C350 Microphone Replacement, Rear case freeing: 1 단계, 이미지 1/2 Motorola C350 Microphone Replacement, Rear case freeing: 1 단계, 이미지 2/2
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. Motorola C350 Microphone Replacement, Removing battery: 2 단계, 이미지 1/1
    • slide the black button to free the battery so you can grab it with your other hand.
  3. Motorola C350 Microphone Replacement, Separating the front case: 3 단계, 이미지 1/2 Motorola C350 Microphone Replacement, Separating the front case: 3 단계, 이미지 2/2
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
  4. Motorola C350 Microphone Replacement, Logic Board: 4 단계, 이미지 1/2 Motorola C350 Microphone Replacement, Logic Board: 4 단계, 이미지 2/2
    • Remove the 4 T6 Torx screws
  5. Motorola C350 Microphone Replacement: 5 단계, 이미지 1/2 Motorola C350 Microphone Replacement: 5 단계, 이미지 2/2
    • Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
  6. Motorola C350 Microphone Replacement: 6 단계, 이미지 1/1
    • The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
  7. Motorola C350 Microphone Replacement, Microphone: 7 단계, 이미지 1/1
    • Use a plastic spudger to unclip the mic.
결론
Vincent Monteil
회원 가입일: 07/06/13
6,975 평판
안내서 19개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 366
