주요 콘텐츠로 건너뛰기
Motorola California Mobile Phone Motherboard Replacement
필요한 것
  1. Motorola California Mobile Phone Motherboard Replacement, Motorola California Mobile Phone Teardown: 1 단계, 이미지 1/1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Motherboard Replacement: 2 단계, 이미지 1/1
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Motherboard Replacement: 3 단계, 이미지 1/1
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
    • Remove the key guard from the rear casing by taking it out of its position.
  4. Motorola California Mobile Phone Motherboard Replacement: 4 단계, 이미지 1/1
    • Locate and unplug the black component of the antenna from the motherboard.
    • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
  5. Motorola California Mobile Phone Motherboard Replacement: 5 단계, 이미지 1/1
    • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
  6. Motorola California Mobile Phone Motherboard Replacement: 6 단계, 이미지 1/1
    • Lift the motherboard out of its location in the front casing.
    • Do this slowly and gently so that none of the motherboard's components are damaged.
  7. Motorola California Mobile Phone Motherboard Replacement, Motherboard: 7 단계, 이미지 1/1
    • With your new motherboard, hold the LCD side of the motherboard face down. Align the four clips on the front casing with the four notches on the motherboard.
    • While doing so, insert the LCD into the compartment in the front casing.
  8. Motorola California Mobile Phone Motherboard Replacement: 8 단계, 이미지 1/1
    • Press firmly on the motherboard until it is snug inside the casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Lam
회원 가입일: 04/17/12
35 평판
안내서 4개 작성하였습니다
Cal Poly, Team 9-46, Regan Spring 2012 Cal Poly, Team 9-46, Regan Spring 2012 회원
CPSU-REGAN-S12S9G46
5 회원들
안내서 8개 작성하였습니다
댓글 한 개
Nice, thanks.
Daniel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 24
전체 시간: 2,859
