주요 콘텐츠로 건너뛰기
Motorola California Mobile Phone Rear Casing Replacement
필요한 것
  1. Motorola California Mobile Phone Rear Casing Replacement, Rear Casing: 1 단계, 이미지 1개 중 1개
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Rear Casing Replacement: 2 단계, 이미지 1개 중 1개
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Rear Casing Replacement: 3 단계, 이미지 1개 중 1개
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the old rear casing away from the rest of the device.
  4. Motorola California Mobile Phone Rear Casing Replacement: 4 단계, 이미지 1개 중 1개
    • Locate the four holes on the new rear casing.
    • Align the holes in the new rear casing with the clips attached the to front casing.
    • Simultaneously insert all four clips.
    • Push down firmly until you hear the clips click into place.
  5. Motorola California Mobile Phone Rear Casing Replacement: 5 단계, 이미지 1개 중 1개
    • Find a thin and sturdy screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the new key pad guard to the rear casing.
    • Use the screwdriver to push the rods away from each other until they click into their locked position.
결론
작성자
7다른 기여자 명과 함께
Andrew Lam
회원 가입일: 04/17/12
53 평판
안내서 4개를 작성함
Cal Poly, Team 9-46, Regan Spring 2012 Cal Poly, Team 9-46, Regan Spring 2012 회원
CPSU-REGAN-S12S9G46
5 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 1,141
