주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola DROID MAXX Full Screen Replacement
필요한 것
  1. Motorola DROID MAXX Full Screen  Replacement, Screen Assembly Replacement: 1 단계, 이미지 3개 중 1개 Motorola DROID MAXX Full Screen  Replacement, Screen Assembly Replacement: 1 단계, 이미지 3개 중 2개 Motorola DROID MAXX Full Screen  Replacement, Screen Assembly Replacement: 1 단계, 이미지 3개 중 3개
    • Find the volume buttons located on the side of the Droid Maxx.
    • Take the plastic opening tool and insert it into the gap between the volume buttons and the case.
    • Using the flat tip of the plastic opening tool, press firmly against the case until you hear a “snap” sound.
    • Remove the buttons carefully. Do not bend or force the part since it also serves as a tray for placing a SIM Card.
  2. Motorola DROID MAXX Full Screen  Replacement: 2 단계, 이미지 3개 중 1개 Motorola DROID MAXX Full Screen  Replacement: 2 단계, 이미지 3개 중 2개 Motorola DROID MAXX Full Screen  Replacement: 2 단계, 이미지 3개 중 3개
    • Using the flat tip of the plastic opening tool, press firmly against the case until you hear an audible click.
    • Once the top part of the case is separated from the frame, grip the bottom part of the rubber case with your finger and slide the case down to remove it completely.
  3. Motorola DROID MAXX Full Screen  Replacement: 3 단계, 이미지 3개 중 1개 Motorola DROID MAXX Full Screen  Replacement: 3 단계, 이미지 3개 중 2개 Motorola DROID MAXX Full Screen  Replacement: 3 단계, 이미지 3개 중 3개
    • Using the Torx T5 Screwdriver, carefully remove all of the screws in the motherboard.
    • There are 8 black screws: 4 at the top and 4 at the bottom of the motherboard.
    • There are 2 silver screws on the side: 1 at the bottom and 1 in the middle.
    • Use either a T3 (Ultra) or T4 (MAXX) to remove the single screw securing the camera housing.
    • Using the plastic opening tool, gently lift the two tabs in the upper plastic cover that surrounds the camera to release the cover.
  4. Motorola DROID MAXX Full Screen  Replacement: 4 단계, 이미지 3개 중 1개 Motorola DROID MAXX Full Screen  Replacement: 4 단계, 이미지 3개 중 2개 Motorola DROID MAXX Full Screen  Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully disconnect the ribbon cable from the motherboard and front screen.
    • Place the ribbon cable under the orange tape during reassembly.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Jordan
회원 가입일: 03/01/17
227 평판
안내서 1개를 작성함
IUPUI, Team S2-G4, Harley Spring 2017 IUPUI, Team S2-G4, Harley Spring 2017 회원
IUPUI-HARLEY-S17S2G4
4 회원들
안내서 1개 작성
2가이드 댓글
Where can I purchase the screen replacement for the droid maxx
Zachary lawson - 답글 공유
That 3mm screw is a ##&&%. BE VERY CAREFUL WITH IT! I haven’t figured out how to best loosen it yet; maybe small turn bursts so you don’t break the tines?
Ron Herren - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 28
전체 시간: 6,750
