주요 콘텐츠로 건너뛰기
Motorola DROID MAXX Rear-Facing Camera Replacement
필요한 것
  1. Motorola DROID MAXX Rear-Facing Camera Replacement, Set Up: 1 단계, 이미지 2개 중 1개 Motorola DROID MAXX Rear-Facing Camera Replacement, Set Up: 1 단계, 이미지 2개 중 2개
    • Place the Droid Maxx face up on a soft flat plastic surface with plenty of space to place your tools and small parts of the equipment.
    • Lift the Droid Maxx and turn it in a 90-degree angle to your left while you are holding it by the sides with one hand. Maintain the same position all times unless indicated otherwise in subsequent steps.
  2. Motorola DROID MAXX Rear-Facing Camera Replacement, Getting Started: 2 단계, 이미지 3개 중 1개 Motorola DROID MAXX Rear-Facing Camera Replacement, Getting Started: 2 단계, 이미지 3개 중 2개 Motorola DROID MAXX Rear-Facing Camera Replacement, Getting Started: 2 단계, 이미지 3개 중 3개
    • Find the volume buttons located towards the center of the Droid Maxx.
    • With your free hand, take the Spudger and insert it between the upper gap, closest to the screen, of the volume buttons and the Droid Maxx case.
    • Using the flat part of the Spudger’s Tip and pressing firmly against the Droid Maxx case until you hear a “snap” sound
    • With your free hand, remove the buttons carefully with your two fingers and make sure to keep the motion until the piece is completely out of your Droid Maxx. Do not bend or force the part since it also serves as a tray for placing a SIM Card.
  3. Motorola DROID MAXX Rear-Facing Camera Replacement, Removing the Back Cover: 3 단계, 이미지 3개 중 1개 Motorola DROID MAXX Rear-Facing Camera Replacement, Removing the Back Cover: 3 단계, 이미지 3개 중 2개 Motorola DROID MAXX Rear-Facing Camera Replacement, Removing the Back Cover: 3 단계, 이미지 3개 중 3개
    • Tilt the Droid Maxx towards your right so you can see the edge of the rubber back case and keep this position.
    • Take the Spudger and press the tip against the space between the rubber case and the Droid Maxx frame. Slide the Spudger’s edge along the surface until you hear a “snap” sound.
    • Work your way to the top of the Droid Maxx with the Spudger and use your holding hand’s fingers as support while you remove the upper part of the rubber back case. Rotate the Droid Maxx to facilitate your movement if necessary. Do not go along the bottom to remove the case.
    • Once the top part of the case is separated from the frame, grip the bottom part of the rubber case with your finger and slide the case down to remove it completely.
    • Place the rubber back case in a nearby place where it will not interfere with your arms motion.
  4. Motorola DROID MAXX Rear-Facing Camera Replacement, Removing the Camera Back Housing: 4 단계, 이미지 3개 중 1개 Motorola DROID MAXX Rear-Facing Camera Replacement, Removing the Camera Back Housing: 4 단계, 이미지 3개 중 2개 Motorola DROID MAXX Rear-Facing Camera Replacement, Removing the Camera Back Housing: 4 단계, 이미지 3개 중 3개
    • Lay the Droid Maxx face down on the plastic surface to start removing the screws.
    • Take the Torx T5 Screwdriver and carefully remove all the screws in the Droid Maxx’s motherboard. Note that there is a total of eight (11) black screws spread across the motherboard, four (4) at the top and four (4) at the bottom, and also two (2) silver screws located to the right lower part of the Droid Maxx.
    • There is(1) screw holding the camera housing. Use a T4 screwdriver for this one screw.
    • After removing all the screws, lift hold the Droid Maxx as in step 2
    • Locate two (2) tabs in the camera plastic housing , one (1) at each corner of the Droid Maxx
    • Take the Flathead driver and gently lift both tabs to release the camera housing. Be careful because these plastic tabs are very delicate and can break easily.
  5. Motorola DROID MAXX Rear-Facing Camera Replacement, Let the Fix Begin!: 5 단계, 이미지 1개 중 1개
    • Now you are all set! These steps along with images should serve as guide to disassemble your Motorola Droid Maxx in a safe manner. The following guides will indicate how to replace parts of your Droid Maxx such as the camera or battery.
    • Keep in mind that in order to replace any of the aforementioned parts you will be redirected to this general section.
  6. Motorola DROID MAXX Rear-Facing Camera Replacement, Rear Facing replacement: 6 단계, 이미지 1개 중 1개
    • Using a prying plastic tool start lifting the motherboard from the assembly.
    • You may need to use a gun heater to soften the adhesive around the assembly.
  7. Motorola DROID MAXX Rear-Facing Camera Replacement, Removing: 7 단계, 이미지 1개 중 1개
    • Use a spudger to lift up the anti-static tape covering the camera connectors. Remove the tape
    • Consider keeping the tape in case you need to reuse it if you don’t have spare tape.
  8. Motorola DROID MAXX Rear-Facing Camera Replacement, Final steps: 8 단계, 이미지 1개 중 1개
    • When the tape is out and the camera connectors disconnected use a plastic opening tool to lift up the tab on the rear-facing camera
    • Push the rear-facing camera and remove it.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Roberto
회원 가입일: 10/07/14
223 평판
안내서 2개를 작성함
USF Tampa, Team 7-6, Leahy Fall 2014 USF Tampa, Team 7-6, Leahy Fall 2014 회원
USFT-LEAHY-F14S7G6
4 회원들
안내서 6개를 작성함
5가이드 댓글
Thank you for the instructions on how to replace the camera, now where can I buy the parts to replace the camera?
bbehrendt - 답글
I bought my new rear-facing camera here:
https://www.fixez.com/
It cost me about $14 with shipping.
Fred Chapman - 답글
I would rate this repair as easy to moderate. The iphone repairs are fair more delicate and prone to problems
Rao Garimella - 답글
there is the best price for cell phone parts
Huili Cheng - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 20
전체 시간: 8,355
