주요 콘텐츠로 건너뛰기
Motorola DROID RAZR MAXX Camera Cover Replacement
필요한 것
  1. Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: 1 단계, 이미지 1/2 Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: 1 단계, 이미지 2/2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola DROID RAZR MAXX Camera Cover Replacement: 2 단계, 이미지 1/2 Motorola DROID RAZR MAXX Camera Cover Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • Continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola DROID RAZR MAXX Camera Cover Replacement: 3 단계, 이미지 1/3 Motorola DROID RAZR MAXX Camera Cover Replacement: 3 단계, 이미지 2/3 Motorola DROID RAZR MAXX Camera Cover Replacement: 3 단계, 이미지 3/3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola DROID RAZR MAXX Camera Cover Replacement: 4 단계, 이미지 1/1
    • Looking at the top rectangular hump where the camera is located, use the plastic opening tool to remove the camera cover.
    • Using the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Govind
회원 가입일: 10/08/14
130 평판
안내서 1개 작성함
USF Tampa, Team 14-6, Leahy Fall 2014 USF Tampa, Team 14-6, Leahy Fall 2014 회원
USFT-LEAHY-F14S14G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 702
