주요 콘텐츠로 건너뛰기
Motorola DROID RAZR MAXX Camera Cover Replacement
필요한 것
  1. Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: 1 단계, 이미지 2개 중 1개 Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: 1 단계, 이미지 2개 중 2개
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola DROID RAZR MAXX Camera Cover Replacement: 2 단계, 이미지 2개 중 1개 Motorola DROID RAZR MAXX Camera Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • Continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola DROID RAZR MAXX Camera Cover Replacement: 3 단계, 이미지 3개 중 1개 Motorola DROID RAZR MAXX Camera Cover Replacement: 3 단계, 이미지 3개 중 2개 Motorola DROID RAZR MAXX Camera Cover Replacement: 3 단계, 이미지 3개 중 3개
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola DROID RAZR MAXX Camera Cover Replacement: 4 단계, 이미지 1개 중 1개
    • Looking at the top rectangular hump where the camera is located, use the plastic opening tool to remove the camera cover.
    • Using the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Govind
회원 가입일: 10/08/14
130 평판
안내서 1개를 작성함
USF Tampa, Team 14-6, Leahy Fall 2014 USF Tampa, Team 14-6, Leahy Fall 2014 회원
USFT-LEAHY-F14S14G6
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 11
전체 시간: 816
