주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Defy Display Assembly Replacement
필요한 것
  1. Motorola Defy Display Assembly Replacement, Display Assembly: 1 단계, 이미지 2개 중 1개 Motorola Defy Display Assembly Replacement, Display Assembly: 1 단계, 이미지 2개 중 2개
    • Remove the battery cover and the battery itself.
  2. Motorola Defy Display Assembly Replacement: 2 단계, 이미지 2개 중 1개 Motorola Defy Display Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Torx T5 screwdriver, remove both screws near the camera.
  3. Motorola Defy Display Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Using the Torx T5 screwdriver, remove all 7 screws around the mobile: 3 on each side + 1 on the botton.
  4. Motorola Defy Display Assembly Replacement: 4 단계, 이미지 3개 중 1개 Motorola Defy Display Assembly Replacement: 4 단계, 이미지 3개 중 2개 Motorola Defy Display Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Using a plastic opener tool, open the device removing the back cover.
    • Remove the power button and volume button.
  5. Motorola Defy Display Assembly Replacement: 5 단계, 이미지 3개 중 1개 Motorola Defy Display Assembly Replacement: 5 단계, 이미지 3개 중 2개 Motorola Defy Display Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • After opening the device, carefully, using the plastic opening tool, peel off the lcd and digitalizer conectors from the mainboard.
  6. Motorola Defy Display Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two yellow rubber protectors near the screws. The rectangular yellow rubber protector might fall off too so put it aside.
  7. Motorola Defy Display Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Separate the Frame + Digitizer, the LCD and the mainboard.
  8. Motorola Defy Display Assembly Replacement: 8 단계, 이미지 3개 중 1개 Motorola Defy Display Assembly Replacement: 8 단계, 이미지 3개 중 2개 Motorola Defy Display Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • Now, using a plastic opening tool, carefully insert it between the frame and the glass and force it slowly to remove the adhesive. You may also heat it to help.
    • Now, Remove the rest of adhesive from the frame to better apply the new digitizer on it.
    • Follow this backwards to reassemble the mobile.
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Leandro Fuscaldi Albergaria
회원 가입일: 01/12/12
285 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 17
지난 30일: 87
전체 시간: 6,086
