주요 콘텐츠로 건너뛰기
Motorola Defy Rear Facing Camera Replacement
필요한 것
  1. Motorola Defy Rear Facing Camera Replacement, Rear Case: 1 단계, 이미지 1/1
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy Rear Facing Camera Replacement: 2 단계, 이미지 1/2 Motorola Defy Rear Facing Camera Replacement: 2 단계, 이미지 2/2
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy Rear Facing Camera Replacement, Battery: 3 단계, 이미지 1/1
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy Rear Facing Camera Replacement, Midframe: 4 단계, 이미지 1/1
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy Rear Facing Camera Replacement: 5 단계, 이미지 1/1
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Motorola Defy Rear Facing Camera Replacement, Rear Facing Camera: 6 단계, 이미지 1/2 Motorola Defy Rear Facing Camera Replacement, Rear Facing Camera: 6 단계, 이미지 2/2
    • Start to pry around the bottom of the camera module with the metal spudger and replace with the new camera module.
    • Be careful of the pins that are connected to the camera module on the bottom.
결론
Morgan Roark
회원 가입일: 10/08/14
325 평판
안내서 3개 작성하였습니다
USF Tampa, Team 14-2, Leahy Fall 2014 USF Tampa, Team 14-2, Leahy Fall 2014 회원
USFT-LEAHY-F14S14G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 406
