주요 콘텐츠로 건너뛰기
Motorola Defy XT Battery Replacement
필요한 것
  1. Motorola Defy XT Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT Battery Replacement: 2 단계, 이미지 1/1
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
  3. Motorola Defy XT Battery Replacement: 3 단계, 이미지 1/1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dorian Capps
회원 가입일: 04/19/13
64 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-22, Maness Spring 2013 Cal Poly, Team 2-22, Maness Spring 2013 회원
CPSU-MANESS-S13S2G22
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
There isn't really much need for guidance on replacing the battery, but it would be helpful if you could provide some details on how long it takes for the first charge after replacement. I connected my charger after replacing the battery and it only lights up the back/menu/home keys below the screen - no indication of battery charging etc. and the phone cannot be powered yet. It's been charging for well over half an hour. Any advice?
shaunschon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,665
