이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
Remove the back cover and set it aside.
Insert the opening tool between the battery and the battery holder and wedge the battery out.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
There isn't really much need for guidance on replacing the battery, but it would be helpful if you could provide some details on how long it takes for the first charge after replacement. I connected my charger after replacing the battery and it only lights up the back/menu/home keys below the screen - no indication of battery charging etc. and the phone cannot be powered yet. It's been charging for well over half an hour. Any advice?
shaunschon - 답글
