주요 콘텐츠로 건너뛰기
Motorola Defy XT Screen Replacement
필요한 것
  1. Motorola Defy XT Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
  3. Motorola Defy XT Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
  4. Motorola Defy XT Screen Replacement, SD Card: 4 단계, 이미지 1개 중 1개
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
  5. Motorola Defy XT Screen Replacement, Screen: 5 단계, 이미지 2개 중 1개 Motorola Defy XT Screen Replacement, Screen: 5 단계, 이미지 2개 중 2개
    • Use the Torx T4 screwdriver to remove the six 3 mm screws from the back case.
  6. Motorola Defy XT Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pop the volume buttons off from the side of the phone.
  7. Motorola Defy XT Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool between the plastic layer and the shiny front cover.
  8. Motorola Defy XT Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Slide the plastic opening tool along the edge, wedging the the two pieces apart.
    • Potential for device damage: Do not completely separate the two pieces; there are still internal components that need to be disconnected.
  9. Motorola Defy XT Screen Replacement: 9 단계, 이미지 2개 중 1개 Motorola Defy XT Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Slide the screen out and disconnect the ribbon cable connecting the display to the motherboard by pulling straight outward.
    • Potential for device damage: Be careful when sliding out the screen because the front case and the motherboard are still connected by two other ribbon cables.
  10. Motorola Defy XT Screen Replacement: 10 단계, 이미지 2개 중 1개 Motorola Defy XT Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Set the old screen aside and replace it with your new screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Oscar Camacho
회원 가입일: 04/19/13
89 평판
안내서 1개를 작성함
Cal Poly, Team 2-22, Maness Spring 2013 Cal Poly, Team 2-22, Maness Spring 2013 회원
CPSU-MANESS-S13S2G22
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 15
전체 시간: 3,315
