주요 콘텐츠로 건너뛰기
Motorola Droid 4 Rear Bezel Replacement
필요한 것
  1. Motorola Droid 4 Rear Bezel Replacement, Removing Rear Panel: 1 단계, 이미지 3개 중 1개 Motorola Droid 4 Rear Bezel Replacement, Removing Rear Panel: 1 단계, 이미지 3개 중 2개 Motorola Droid 4 Rear Bezel Replacement, Removing Rear Panel: 1 단계, 이미지 3개 중 3개
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Motorola Droid 4 Rear Bezel Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
  3. Motorola Droid 4 Rear Bezel Replacement: 3 단계, 이미지 2개 중 1개 Motorola Droid 4 Rear Bezel Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    T5 Torx Screwdriver
    $5.49
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
  4. Motorola Droid 4 Rear Bezel Replacement, Camera Cover Removal: 4 단계, 이미지 3개 중 1개 Motorola Droid 4 Rear Bezel Replacement, Camera Cover Removal: 4 단계, 이미지 3개 중 2개 Motorola Droid 4 Rear Bezel Replacement, Camera Cover Removal: 4 단계, 이미지 3개 중 3개
    • Using the blue plastic opening tool, pry off the thin plastic camera cover.
    • The plastic cover is fragile, so proceed carefully.
  5. Motorola Droid 4 Rear Bezel Replacement, Remove Screws: 5 단계, 이미지 2개 중 1개 Motorola Droid 4 Rear Bezel Replacement, Remove Screws: 5 단계, 이미지 2개 중 2개
    • Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit.
    • The screws are philips 2.5mm. One screw is a different color (silver) from the others (black).
  6. Motorola Droid 4 Rear Bezel Replacement, Remove Bezel: 6 단계, 이미지 3개 중 1개 Motorola Droid 4 Rear Bezel Replacement, Remove Bezel: 6 단계, 이미지 3개 중 2개 Motorola Droid 4 Rear Bezel Replacement, Remove Bezel: 6 단계, 이미지 3개 중 3개
    • Insert the spudger between the rear bezel and the main housing.
    • The bezel is fragile, so proceed carefully.
    • Slide the spudger around all sides of the phone to separate the bezel from the housing.
    • Pry the bezel free.
    • Be careful of the adhesive that holds the bezel to the main housing. Prying too hard may damage your phone.
결론
작성자
4다른 기여자 명과 함께
Cheriann
회원 가입일: 09/23/14
156 평판
안내서 1개를 작성함
USF Tampa, Team 5-1, Mcgee Fall 2014 USF Tampa, Team 5-1, Mcgee Fall 2014 회원
USFT-MCGEE-F14S5G1
5 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 562
