주요 콘텐츠로 건너뛰기
Motorola Droid 4 SIM Card Replacement
필요한 것
  1. Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: 1 단계, 이미지 1/3 Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: 1 단계, 이미지 2/3 Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: 1 단계, 이미지 3/3
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: 2 단계, 이미지 1/3 Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: 2 단계, 이미지 2/3 Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: 2 단계, 이미지 3/3
    • Using tweezers or your finger, lift the rubber SIM card cover to expose the card itself.
  3. Motorola Droid 4 SIM Card Replacement, Removing SIM card: 3 단계, 이미지 1/3 Motorola Droid 4 SIM Card Replacement, Removing SIM card: 3 단계, 이미지 2/3 Motorola Droid 4 SIM Card Replacement, Removing SIM card: 3 단계, 이미지 3/3
    • While holding the cover open, use your finger to press and slide out the SIM card.
    • When reinserting the SIM card, make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
  4. Motorola Droid 4 SIM Card Replacement, Insert new SIM card: 4 단계, 이미지 1/3 Motorola Droid 4 SIM Card Replacement, Insert new SIM card: 4 단계, 이미지 2/3 Motorola Droid 4 SIM Card Replacement, Insert new SIM card: 4 단계, 이미지 3/3
    • Follow the same steps in the opposite order to install the new SIM card.
    • Make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Javier
회원 가입일: 09/29/14
530 평판
안내서 4개 작성하였습니다
USF Tampa, Team 5-1, Mcgee Fall 2014 USF Tampa, Team 5-1, Mcgee Fall 2014 회원
USFT-MCGEE-F14S5G1
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 3,544
