도구
부품
Remove the two silver T4 screws securing the SIM tray.
Carefully lift the SIM tray to disconnect it from the board.
Carefully remove the plastic spacer beneath by lifting gently in the center with a plastic removal tool.
Then, using a plastic removal tool, disconnect the speaker & front facing camera assembly from the board. The speaker is attached with adhesive, so be careful not to rip the flex cable.
다른 4명이 해당 안내서를 완성하였습니다.
