주요 콘텐츠로 건너뛰기
Motorola Droid Bionic LCD Replacement
필요한 것
  1. Motorola Droid Bionic LCD Replacement, LCD: 1 단계, 이미지 1개 중 1개
    • Remove the back battery cover.
  2. Motorola Droid Bionic LCD Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery
  3. Motorola Droid Bionic LCD Replacement: 3 단계, 이미지 2개 중 1개 Motorola Droid Bionic LCD Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 11 T4 Torx Screws
    • Next, remove the information sticker.
  4. Motorola Droid Bionic LCD Replacement: 4 단계, 이미지 2개 중 1개 Motorola Droid Bionic LCD Replacement: 4 단계, 이미지 2개 중 2개
    • Using a plastic removal tool, work around the edges of the back housing.
    • Lift off the back housing.
  5. Motorola Droid Bionic LCD Replacement: 5 단계, 이미지 3개 중 1개 Motorola Droid Bionic LCD Replacement: 5 단계, 이미지 3개 중 2개 Motorola Droid Bionic LCD Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two silver T4 screws securing the SIM tray.
    • Carefully lift the SIM tray to disconnect it from the board.
    • Carefully remove the plastic spacer beneath by lifting gently in the center with a plastic removal tool.
    • Then, using a plastic removal tool, disconnect the speaker & front facing camera assembly from the board. The speaker is attached with adhesive, so be careful not to rip the flex cable.
  6. Motorola Droid Bionic LCD Replacement: 6 단계, 이미지 1개 중 1개
    • Disconnect the 2 digitizer connectors using a plastic removal tool.
    • Then disconnect the LCD connector
  7. Motorola Droid Bionic LCD Replacement: 7 단계, 이미지 2개 중 1개 Motorola Droid Bionic LCD Replacement: 7 단계, 이미지 2개 중 2개
    • The board is now free from all connections. Carefully lift from the top and remove the board.
  8. Motorola Droid Bionic LCD Replacement: 8 단계, 이미지 2개 중 1개 Motorola Droid Bionic LCD Replacement: 8 단계, 이미지 2개 중 2개
    • Carefully peel the two flex cables from the back housing of the LCD. Be exceptionally careful during this process, as those flex cables can be easily ripped.
    • With the flex cables out of the way, you can now use a plastic opening tool to carefully pry the old LCD loose and out of the display.
    • If you're installing a new LCD, simply add it now and follow these instructions in reverse to complete the installation.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Taylor
회원 가입일: 08/30/12
244 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 1,861
