주요 콘텐츠로 건너뛰기
Motorola Droid Camera Assembly Replacement
필요한 것
  1. Motorola Droid Camera Assembly Replacement, Battery: 1 단계, 이미지 3개 중 1개 Motorola Droid Camera Assembly Replacement, Battery: 1 단계, 이미지 3개 중 2개 Motorola Droid Camera Assembly Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
    • Lift and remove the battery cover out from the phone.
  2. Motorola Droid Camera Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Grasp the upper left corner of the battery and lift it out of its housing.
  3. Motorola Droid Camera Assembly Replacement, Rear Case: 3 단계, 이미지 1개 중 1개
    • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
    • The cover is attached by adhesive, so some force may be required.
  4. Motorola Droid Camera Assembly Replacement: 4 단계, 이미지 2개 중 1개 Motorola Droid Camera Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
    • Peel the ribbon up off the phone.
  5. Motorola Droid Camera Assembly Replacement: 5 단계, 이미지 2개 중 1개 Motorola Droid Camera Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully peel the device information label that covers the motherboard EMI shields.
    • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
  6. Motorola Droid Camera Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  7. Motorola Droid Camera Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  8. Motorola Droid Camera Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  9. Motorola Droid Camera Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  10. Motorola Droid Camera Assembly Replacement: 10 단계, 이미지 2개 중 1개 Motorola Droid Camera Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  11. Motorola Droid Camera Assembly Replacement: 11 단계, 이미지 2개 중 1개 Motorola Droid Camera Assembly Replacement: 11 단계, 이미지 2개 중 2개
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
  12. Motorola Droid Camera Assembly Replacement, Speaker: 12 단계, 이미지 1개 중 1개
    • Carefully lift and remove the speaker assembly up out of the phone.
  13. Motorola Droid Camera Assembly Replacement, Motherboard: 13 단계, 이미지 3개 중 1개 Motorola Droid Camera Assembly Replacement, Motherboard: 13 단계, 이미지 3개 중 2개 Motorola Droid Camera Assembly Replacement, Motherboard: 13 단계, 이미지 3개 중 3개
    • Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
    • De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
  14. Motorola Droid Camera Assembly Replacement: 14 단계, 이미지 1개 중 1개
    • Peel the black tape covering the side button and display ribbon connectors on the motherboard.
  15. Motorola Droid Camera Assembly Replacement: 15 단계, 이미지 1개 중 1개
    • Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
  16. Motorola Droid Camera Assembly Replacement: 16 단계, 이미지 1개 중 1개
    • Disconnect the display ribbon connector from its socket on the motherboard using the flat end of a spudger.
  17. Motorola Droid Camera Assembly Replacement: 17 단계, 이미지 1개 중 1개
    • Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
    • Don't attempt to remove the motherboard yet, it is still attached by the keypad ribbon connector.
  18. Motorola Droid Camera Assembly Replacement: 18 단계, 이미지 2개 중 1개 Motorola Droid Camera Assembly Replacement: 18 단계, 이미지 2개 중 2개
    • Carefully lift the motherboard from the front case and lay it next to the Droid, minding the keypad connector that is still attached.
    • Disconnect the keypad connector by prying it straight up off its socket on the motherboard.
    • Remove the motherboard from the phone.
  19. Motorola Droid Camera Assembly Replacement, Camera Assembly: 19 단계, 이미지 2개 중 1개 Motorola Droid Camera Assembly Replacement, Camera Assembly: 19 단계, 이미지 2개 중 2개
    • Orient the motherboard so that the camera lens is face down.
    • Disconnect the camera connector from its socket by prying it straight up with a spudger.
    • Remove the camera assembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Matthew Newsom
회원 가입일: 01/05/10
41,996 평판
안내서 67개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 12,713
