주요 콘텐츠로 건너뛰기
Motorola Droid MAXX 2 Button Assembly Replacement
필요한 것
  1. Motorola Droid MAXX 2 Button Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Button Assembly Replacement: 2 단계, 이미지 1/1
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Button Assembly Replacement: 3 단계, 이미지 1/2 Motorola Droid MAXX 2 Button Assembly Replacement: 3 단계, 이미지 2/2
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Button Assembly Replacement: 4 단계, 이미지 1/1
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Button Assembly Replacement: 5 단계, 이미지 1/1
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Button Assembly Replacement: 6 단계, 이미지 1/3 Motorola Droid MAXX 2 Button Assembly Replacement: 6 단계, 이미지 2/3 Motorola Droid MAXX 2 Button Assembly Replacement: 6 단계, 이미지 3/3
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Button Assembly Replacement: 7 단계, 이미지 1/1
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Button Assembly Replacement, Button Assembly: 8 단계, 이미지 1/2 Motorola Droid MAXX 2 Button Assembly Replacement, Button Assembly: 8 단계, 이미지 2/2
    • Peel back the orange adhesive covering the ZIF connector.
  9. Motorola Droid MAXX 2 Button Assembly Replacement: 9 단계, 이미지 1/2 Motorola Droid MAXX 2 Button Assembly Replacement: 9 단계, 이미지 2/2
    • Lift the black tab on the ZIF connector up.
    • Pull the ribbon cable out of the ZIF connector.
  10. Motorola Droid MAXX 2 Button Assembly Replacement: 10 단계, 이미지 1/3 Motorola Droid MAXX 2 Button Assembly Replacement: 10 단계, 이미지 2/3 Motorola Droid MAXX 2 Button Assembly Replacement: 10 단계, 이미지 3/3
    • Use the plastic spudger to loosen the metal prongs that hold the button assembly onto the phone.
  11. Motorola Droid MAXX 2 Button Assembly Replacement: 11 단계, 이미지 1/1
    • Pull the button assembly up and out of the phone.
결론
Burke Seggerman
회원 가입일: 03/18/18
704 평판
안내서 5개 작성하였습니다
Baylor, Team S3-G4, Williams Spring 2018 Baylor, Team S3-G4, Williams Spring 2018 회원
BU-WILLIAMS-S18S3G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 524
