주요 콘텐츠로 건너뛰기
Motorola Droid MAXX 2 Earpiece Speaker Replacement
필요한 것
  1. Motorola Droid MAXX 2 Earpiece Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Earpiece Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Earpiece Speaker Replacement: 3 단계, 이미지 2개 중 1개 Motorola Droid MAXX 2 Earpiece Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Earpiece Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Earpiece Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Earpiece Speaker Replacement: 6 단계, 이미지 3개 중 1개 Motorola Droid MAXX 2 Earpiece Speaker Replacement: 6 단계, 이미지 3개 중 2개 Motorola Droid MAXX 2 Earpiece Speaker Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Earpiece Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Earpiece Speaker Replacement, Earpiece Speaker: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Grab the speaker with the tweezers and gently pull up on the speaker.
    • The speaker is held in place around the edges with adhesive, so there will be some resistance when you try to remove the speaker from the phone.
결론
작성자
8다른 기여자 명과 함께
Burke Seggerman
회원 가입일: 03/18/18
704 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 759
