주요 콘텐츠로 건너뛰기
Motorola Droid MAXX 2 Rear Camera Replacement
필요한 것
  1. Motorola Droid MAXX 2 Rear Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Rear Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Rear Camera Replacement: 3 단계, 이미지 2개 중 1개 Motorola Droid MAXX 2 Rear Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Rear Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Rear Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Rear Camera Replacement: 6 단계, 이미지 3개 중 1개 Motorola Droid MAXX 2 Rear Camera Replacement: 6 단계, 이미지 3개 중 2개 Motorola Droid MAXX 2 Rear Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Rear Camera Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Rear Camera Replacement, Rear Camera: 8 단계, 이미지 1개 중 1개
    • Peel up orange adhesive that covers the ZIF connector.
  9. Motorola Droid MAXX 2 Rear Camera Replacement: 9 단계, 이미지 1개 중 1개
    • Use a spudger to lift up the black tab on the ZIF connector.
    • Remove the camera.
결론
작성자
6다른 기여자 명과 함께
Burke Seggerman
회원 가입일: 03/18/18
704 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 410
