주요 콘텐츠로 건너뛰기
Motorola Droid MAXX 2 Screen Only Replacement
필요한 것
  1. Motorola Droid MAXX 2 Screen Only Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Screen Only Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Screen Only Replacement: 3 단계, 이미지 2개 중 1개 Motorola Droid MAXX 2 Screen Only Replacement: 3 단계, 이미지 2개 중 2개
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Screen Only Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Screen Only Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Screen Only Replacement: 6 단계, 이미지 3개 중 1개 Motorola Droid MAXX 2 Screen Only Replacement: 6 단계, 이미지 3개 중 2개 Motorola Droid MAXX 2 Screen Only Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Screen Only Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Screen Only Replacement, Screen Assembly: 8 단계, 이미지 2개 중 1개 Motorola Droid MAXX 2 Screen Only Replacement, Screen Assembly: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • We will be removing these 3 ribbon cables.
    • Using an opening pick, lift the grey tab on the rear camera's ZIF connector. Remove the ribbon cable and the camera.
    • Use tweezers to lift up on the grey latch on the ZIF connector.
    • Remove the ribbon cable from the ZIF connector.
  9. Motorola Droid MAXX 2 Screen Only Replacement: 9 단계, 이미지 2개 중 1개 Motorola Droid MAXX 2 Screen Only Replacement: 9 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to lift up the black latch on the ZIF connector.
    • Pull the ribbon cable out of the ZIF connector.
  10. Motorola Droid MAXX 2 Screen Only Replacement: 10 단계, 이미지 3개 중 1개 Motorola Droid MAXX 2 Screen Only Replacement: 10 단계, 이미지 3개 중 2개 Motorola Droid MAXX 2 Screen Only Replacement: 10 단계, 이미지 3개 중 3개
    • Using a metal spudger, work your way around the perimeter of the main board and screen.
    • There is a lot of adhesive between the two pieces, so be careful to try to remove the adhesive slowly in order to not break anything.
  11. Motorola Droid MAXX 2 Screen Only Replacement, Screen Only: 11 단계, 이미지 2개 중 1개 Motorola Droid MAXX 2 Screen Only Replacement, Screen Only: 11 단계, 이미지 2개 중 2개
    • Use an opening pick or metal jimmy to carefully peel up a corner of this section of copper tape.
    • Slowly peel the entire piece of copper tape off of the frame, trying not to tear or kink it. Set aside and re-install after attaching new display.
    • Using the pointy tip of a spudger, detach these display cable tabs from the frame.
  12. Motorola Droid MAXX 2 Screen Only Replacement: 12 단계, 이미지 2개 중 1개 Motorola Droid MAXX 2 Screen Only Replacement: 12 단계, 이미지 2개 중 2개
    • Carefully peel up the bottom part of this piece of copper tape and fold it over.
    • Using the point of a spudger, detach this display cable tab from the frame.
    • The plastic edge around the digitizer is very fragile. Use caution when separating the adhesive.
    • Heat the top bezel to soften the adhesive and carefully start removing the display from the frame using a plastic opening picks and a metal jimmy as necessary.
    • The display cable is lightly adhered to the frame. Remove the display starting from the top.
결론
작성자
1다른 기여자 명과 함께
Patrick
회원 가입일: 05/14/14
6,767 평판
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 486
