주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Droid Pro Keyboard Replacement
필요한 것
  1. Motorola Droid Pro Keyboard Replacement, SD Card/SIM Card PCB Board: 1 단계, 이미지 2개 중 1개 Motorola Droid Pro Keyboard Replacement, SD Card/SIM Card PCB Board: 1 단계, 이미지 2개 중 2개
    • Remove the back cover and battery by using the thumb tabs.
  2. Motorola Droid Pro Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew the 8 back panel screws using the T4 Torx screwdriver.
  3. Motorola Droid Pro Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Use a spudger to open the phone along the sides between the back panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use a little force to unlock them.
    • Go around on all sides then pull the back panel off.
  4. Motorola Droid Pro Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Motorola Droid Pro Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Gently lift the SD & SIM card board (PCB) as shown in the following pictures.
    • This will expose the ribbon cable attached to the board and another ribbon cable for the mother board. Remove them both using the spudger.
    • Once the small one is removed the small board can be pulled off.
  5. Motorola Droid Pro Keyboard Replacement, Screen: 5 단계, 이미지 1개 중 1개
    • Unscrew the 6 screws using the T5 Torx screwdriver.
  6. Motorola Droid Pro Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Unlock the ribbon cable and then you can pull the screen out.
    • When replacing screen make sure you lock the ribbon cable back in place.
  7. Motorola Droid Pro Keyboard Replacement, Keyboard: 7 단계, 이미지 1개 중 1개
    • Pop out key board using a spudger on the marked points.
    • The keyboard is locked in place, but can pop in and out. You may need to use a little force to get it out.
    • Once out you can pop the new keyboard in the opposite way you took it out.
결론
작성자
6다른 기여자 명과 함께
Peter Cakounes
회원 가입일: 10/21/14
19 평판
안내서 4개를 작성함
UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G8
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 10
전체 시간: 287
