주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Droid Pro Keyboard Replacement
필요한 것
  1. Motorola Droid Pro Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Motorola Droid Pro Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Motorola Droid Pro Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery using the thumb tab.
  3. Motorola Droid Pro Keyboard Replacement, SD Card/SIM Card PCB Board: 3 단계, 이미지 2개 중 1개 Motorola Droid Pro Keyboard Replacement, SD Card/SIM Card PCB Board: 3 단계, 이미지 2개 중 2개
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Motorola Droid Pro Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Motorola Droid Pro Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Motorola Droid Pro Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Motorola Droid Pro Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Motorola Droid Pro Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
  6. Motorola Droid Pro Keyboard Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 Motorola Droid Pro Keyboard Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
    • Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
    • There are small tabs on the side of the connectors to wedge your tool under.
  7. Motorola Droid Pro Keyboard Replacement: 7 단계, 이미지 2개 중 1개 Motorola Droid Pro Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
  8. Motorola Droid Pro Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Motorola Droid Pro Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
    • This cable is fragile so be careful when disconnecting and moving it around.
  9. Motorola Droid Pro Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Use a T5 Torx Screwdriver to unscrew the 2mm screw.
  10. Motorola Droid Pro Keyboard Replacement: 10 단계, 이미지 3개 중 1개 Motorola Droid Pro Keyboard Replacement: 10 단계, 이미지 3개 중 2개 Motorola Droid Pro Keyboard Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the camera's rubber seal by pulling it off. It is not connected to anything.
  11. Motorola Droid Pro Keyboard Replacement: 11 단계, 이미지 2개 중 1개 Motorola Droid Pro Keyboard Replacement: 11 단계, 이미지 2개 중 2개
    • To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
  12. Motorola Droid Pro Keyboard Replacement, Screen: 12 단계, 이미지 2개 중 1개 Motorola Droid Pro Keyboard Replacement, Screen: 12 단계, 이미지 2개 중 2개
    • Use a T4 Torx Screwdriver to remove the (6) 1mm screws.
  13. Motorola Droid Pro Keyboard Replacement: 13 단계, 이미지 3개 중 1개 Motorola Droid Pro Keyboard Replacement: 13 단계, 이미지 3개 중 2개 Motorola Droid Pro Keyboard Replacement: 13 단계, 이미지 3개 중 3개
    • Using a plastic opening tool or spudger lift the rear screen plate up and pull it off.
  14. Motorola Droid Pro Keyboard Replacement: 14 단계, 이미지 3개 중 1개 Motorola Droid Pro Keyboard Replacement: 14 단계, 이미지 3개 중 2개 Motorola Droid Pro Keyboard Replacement: 14 단계, 이미지 3개 중 3개
    • Unlock the screen's ribbon cable.
    • The mechanism that locks the ribbon cable in place for the screen is very weak, so be careful.
    • To remove the screen, you have to flip the phone over and let it fall out slowly into your hand. Be careful not to put any tension on the ribbon cable.
    • Then pull the screen away from the ribbon cable connector and it will slide out easily. Do not use excessive force.
  15. Motorola Droid Pro Keyboard Replacement, Keyboard: 15 단계, 이미지 2개 중 1개 Motorola Droid Pro Keyboard Replacement, Keyboard: 15 단계, 이미지 2개 중 2개
    • Disconnect the last cable.
    • Then use a plastic opening tool to pop out the keyboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kyle Shays
회원 가입일: 10/28/15
836 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-6, Miles Fall 2015 UMass Dartmouth, Team 1-6, Miles Fall 2015 회원
UMASSD-MILES-F15S1G6
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 46
전체 시간: 1,428
