주요 콘텐츠로 건너뛰기
Motorola Droid Pro SD Card/SIM Card PCB Board Replacement
필요한 것
  1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: 1 단계, 이미지 1/2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: 1 단계, 이미지 2/2
    • Remove the back cover and battery by using the thumb tabs.
  2. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 2 단계, 이미지 1/1
    • Unscrew the 8 back panel screws using the T4 Torx screwdriver.
  3. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 3 단계, 이미지 1/1
    • Use a spudger to open the phone along the sides between the back panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use a little force to unlock them.
    • Go around on all sides then pull the back panel off.
  4. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 4 단계, 이미지 1/2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 4 단계, 이미지 2/2
    • Gently lift the SD & SIM card board (PCB) as shown in the following pictures.
    • This will expose the ribbon cable attached to the board and another ribbon cable for the mother board. Remove them both using the spudger.
    • Once the small one is removed the small board can be pulled off.
결론
Peter Cakounes
회원 가입일: 10/21/14
19 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G8
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 193
