주요 콘텐츠로 건너뛰기
Motorola Droid Pro SD Card/SIM Card PCB Board Replacement
필요한 것
  1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 2 단계, 이미지 2개 중 1개 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery using the thumb tab.
  3. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: 3 단계, 이미지 2개 중 1개 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: 3 단계, 이미지 2개 중 2개
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 4 단계, 이미지 3개 중 1개 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 4 단계, 이미지 3개 중 2개 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 5 단계, 이미지 2개 중 1개 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 5 단계, 이미지 2개 중 2개
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kyle Shays
회원 가입일: 10/28/15
836 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-6, Miles Fall 2015 UMass Dartmouth, Team 1-6, Miles Fall 2015 회원
UMASSD-MILES-F15S1G6
3 회원들
안내서 12개를 작성함
1가이드 댓글
Does the replacement board have to be from the same phone or does any sim board work from any phone as long as it's 3g
lisa marie - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 435
