주요 콘텐츠로 건너뛰기
Motorola Droid Pro SD Card/SIM Card PCB Board Replacement
필요한 것
  1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 2 단계, 이미지 1/2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 2 단계, 이미지 2/2
    • Remove the battery using the thumb tab.
  3. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: 3 단계, 이미지 1/2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: 3 단계, 이미지 2/2
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 4 단계, 이미지 1/3 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 4 단계, 이미지 2/3 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 4 단계, 이미지 3/3
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 5 단계, 이미지 1/2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 5 단계, 이미지 2/2
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kyle Shays
회원 가입일: 10/28/15
836 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 1-6, Miles Fall 2015 UMass Dartmouth, Team 1-6, Miles Fall 2015 회원
UMASSD-MILES-F15S1G6
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
Does the replacement board have to be from the same phone or does any sim board work from any phone as long as it's 3g
lisa marie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 281
