주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Droid RAZR Camera Cover Replacement
필요한 것
  1. Motorola Droid RAZR Camera Cover Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Motorola Droid RAZR Camera Cover Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Camera Cover Replacement: 2 단계, 이미지 3개 중 1개 Motorola Droid RAZR Camera Cover Replacement: 2 단계, 이미지 3개 중 2개 Motorola Droid RAZR Camera Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Camera Cover Replacement: 3 단계, 이미지 3개 중 1개 Motorola Droid RAZR Camera Cover Replacement: 3 단계, 이미지 3개 중 2개 Motorola Droid RAZR Camera Cover Replacement: 3 단계, 이미지 3개 중 3개
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
  4. Motorola Droid RAZR Camera Cover Replacement, Battery: 4 단계, 이미지 2개 중 1개 Motorola Droid RAZR Camera Cover Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
  5. Motorola Droid RAZR Camera Cover Replacement: 5 단계, 이미지 3개 중 1개 Motorola Droid RAZR Camera Cover Replacement: 5 단계, 이미지 3개 중 2개 Motorola Droid RAZR Camera Cover Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two 3.3 mm T5 Torx battery terminal screws.
    • Grab the blue battery removal tab and lift the battery out to remove it.
    • There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
    • Your phone will have a number of metal EMI shields on the motherboard, rather than the bare ICs seen here.
  6. Motorola Droid RAZR Camera Cover Replacement, Camera Cover: 6 단계, 이미지 2개 중 1개 Motorola Droid RAZR Camera Cover Replacement, Camera Cover: 6 단계, 이미지 2개 중 2개
    • Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
    • The following steps were performed without the use of a heat gun. Notice that the camera cover cracks very easily if you do not heat the adhesive that holds it in place.
    • Gently pry up the bottom edge of the camera cover with a plastic opening tool.
    • Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
    • Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
  7. Motorola Droid RAZR Camera Cover Replacement: 7 단계, 이미지 3개 중 1개 Motorola Droid RAZR Camera Cover Replacement: 7 단계, 이미지 3개 중 2개 Motorola Droid RAZR Camera Cover Replacement: 7 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool underneath the top edge of the camera cover.
    • Gently pry the camera cover up as you slide the plastic opening tool across the top edge to free it from the adhesive.
    • Remove the camera cover.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
David Hodson
회원 가입일: 04/13/10
155,240 평판
안내서 127개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 43
전체 시간: 4,933
