주요 콘텐츠로 건너뛰기
Motorola Droid RAZR HD Rear Facing Camera Replacement
필요한 것
  1. Motorola Droid RAZR HD Rear Facing Camera Replacement, Front Panel Assembly: 1 단계, 이미지 1/1
    • Power off the device before disassembly to avoid damage or harm from electrical surges.
    • Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
  2. Motorola Droid RAZR HD Rear Facing Camera Replacement: 2 단계, 이미지 1/1
    • Holding the device in your hand, push the screen towards the top of the phone until it disconnects from the base of the phone.
  3. Motorola Droid RAZR HD Rear Facing Camera Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to lift the screen from the phone.
    • Do not try to completely detach the screen; cables are still connected to the device and can be damaged.
  4. Motorola Droid RAZR HD Rear Facing Camera Replacement: 4 단계, 이미지 1/2 Motorola Droid RAZR HD Rear Facing Camera Replacement: 4 단계, 이미지 2/2
    • Use tweezers to remove the yellow tape covering the lcd/digitizer cable connector.
    • Carefully lift up the black locking tab to release the lcd/digitizer cable.
    • The cable connector is located on the bottom right section of the phone.
  5. Motorola Droid RAZR HD Rear Facing Camera Replacement: 5 단계, 이미지 1/1
    • Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
    • This connector is located on the top right section of the phone.
    • Use tweezers to lift the black bar on top of the ZIF connector.
    • Pull the ribbon cable out of the connector with tweezers.
    • Now that there are no cables connecting the screen to the motherboard, remove the screen.
  6. Motorola Droid RAZR HD Rear Facing Camera Replacement, Rear Facing Camera: 6 단계, 이미지 1/2 Motorola Droid RAZR HD Rear Facing Camera Replacement, Rear Facing Camera: 6 단계, 이미지 2/2
    • Remove the two 3.5mm Torx T4 screws securing the rear facing camera.
    • Using tweezers, remove the metal shield protecting the rear facing camera.
  7. Motorola Droid RAZR HD Rear Facing Camera Replacement: 7 단계, 이미지 1/2 Motorola Droid RAZR HD Rear Facing Camera Replacement: 7 단계, 이미지 2/2
    • Use a plastic opening tool to lift up the rear camera.
    • Use tweezers to lift and unlock the black bar on top of the rear camera's ZIF connector.
    • Pull the camera out of the connector.
    • You will need to unplug the rear camera from its connector on the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ryan Meinhardt
회원 가입일: 04/14/15
346 평판
안내서 1개 작성함
Cal Poly, Team 4-4, Maness Spring 2015 Cal Poly, Team 4-4, Maness Spring 2015 회원
CPSU-MANESS-S15S4G4
5 회원들
안내서 12개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 383
