주요 콘텐츠로 건너뛰기
Motorola Droid RAZR M Battery Door Glass Lens Replacement
필요한 것
  1. Motorola Droid RAZR M Battery Door Glass Lens Replacement, Battery Door Glass Lens: 1 단계, 이미지 1/1
    • Shattered!
  2. Motorola Droid RAZR M Battery Door Glass Lens Replacement: 2 단계, 이미지 1/1
    • Glass won't just pop off. It is held by a very sticky tape. Carefully scraping the tape with the glass pieces off and vacuum the area after to prevent a clean surface.
    • Be aware of jumping tiny glass pieces during process. Protect your eyes and area around you. They can get stuck in skin too.
  3. Motorola Droid RAZR M Battery Door Glass Lens Replacement: 3 단계, 이미지 1/1
    • To replace the part you first need to attach the sticky tape. It comes in the correct outlines. Take the inner parts out to keep those areas free (Camera, Flash, Loudspeaker and a hole).
    • Before you take the film off practice the attaching. You will have it hard to reposition after its attached. Same goes with the lens itself, practice before the tape film is off. Once you feel safe to go, peel the film off and go for it!
  4. Motorola Droid RAZR M Battery Door Glass Lens Replacement: 4 단계, 이미지 1/1
    • Done :-)
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Alex R
회원 가입일: 09/27/13
215 평판
안내서 1개 작성함
댓글 3개
This is not a razr maxx !!!!
Fausto Lebron - 답글
This isn't a Razr Maxx. The back doesn't have glass on a razr maxx.
Alex Tucker - 답글
This is Droid razr m . not maxx
Qais Afridi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 7,377
