이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will walk you through removing the battery from the Motorola Droid RAZR M. Before you can access the battery, the front assembly and the motherboard need to be removed. The battery is located in the rear assembly.
If your battery is swollen, take appropriate precautions.
필요한 것
Open the small latch on the left side of the device by lifting gently with your finger, exposing the SIM card and microSD card slots.
If either of these cards are present, remove them to prevent damaging them while taking apart the phone. Our device does not have either.
Close the latch once the two cards are removed.
Run the plastic opening tool under the bottom edge of the phone to detach the small plastic cover below the Verizon logo.
It will take some force to remove this piece. Work around the bottom corners to unlatch the two hooks holding the piece in place.
Once the plastic cover is detached, pull the piece away with your fingers.
Like a clamshell, slowly open the device from the top. Open the remainder of the device slowly while being mindful of the flat orange wire that connects the motherboard to the front assembly.
Undo the snap connection in the lower left corner by inserting the plastic opening tool under the end of the orange wire connected to the motherboard. Lift gently.
Once the snap connection is undone, pull apart the front assembly from the rest of the phone.
Remove the six 4mm T5 Torx screws located along the outer edge of the motherboard.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 6개
Thank you! This phone is really well-built, and a bear to disassemble. This guide had exactly what I needed to see.
this was a rockin' guide!!! looked everywhere and here it is, and yes a bear but a cool one!
Thank You! Hope this new battery works better than the old one!
Yeah it's kind of helpful.
