주요 콘텐츠로 건너뛰기
Motorola Droid RAZR Maxx Metal Chassis Replacement
필요한 것
  1. Motorola Droid RAZR Maxx Metal Chassis Replacement, Metal Chassis: 1 단계, 이미지 1/2 Motorola Droid RAZR Maxx Metal Chassis Replacement, Metal Chassis: 1 단계, 이미지 2/2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola Droid RAZR Maxx Metal Chassis Replacement: 2 단계, 이미지 1/2 Motorola Droid RAZR Maxx Metal Chassis Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • After this continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola Droid RAZR Maxx Metal Chassis Replacement: 3 단계, 이미지 1/3 Motorola Droid RAZR Maxx Metal Chassis Replacement: 3 단계, 이미지 2/3 Motorola Droid RAZR Maxx Metal Chassis Replacement: 3 단계, 이미지 3/3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola Droid RAZR Maxx Metal Chassis Replacement: 4 단계, 이미지 1/1
    • Looking at the top rectangular hump where the camera is located, you will now use the plastic opening tool to remove the camera cover.
    • With the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
  5. Motorola Droid RAZR Maxx Metal Chassis Replacement: 5 단계, 이미지 1/3 Motorola Droid RAZR Maxx Metal Chassis Replacement: 5 단계, 이미지 2/3 Motorola Droid RAZR Maxx Metal Chassis Replacement: 5 단계, 이미지 3/3
    • Using the T5 and T4 bit pieces, remove the silver screws located around the rear case of the phone.
    • Remove the three 6.7 mm silver T4 screws that are located at the top of the phone.
    • Remove the five 4.0 mm silver T5 screws that are located near the middle of the phone.
  6. Motorola Droid RAZR Maxx Metal Chassis Replacement: 6 단계, 이미지 1/1
    • Using the T4 bit piece remove the three black 4.5 mm screws that are located at the bottom of the phone.
  7. Motorola Droid RAZR Maxx Metal Chassis Replacement: 7 단계, 이미지 1/3 Motorola Droid RAZR Maxx Metal Chassis Replacement: 7 단계, 이미지 2/3 Motorola Droid RAZR Maxx Metal Chassis Replacement: 7 단계, 이미지 3/3
    • Insert the plastic opening tool between the rear case and motherboard assembly.
    • Using the plastic opening tool, carefully work your way around the phone, freeing the plastic clips.
    • Carefully pull the rear case off the motherboard assembly.
  8. Motorola Droid RAZR Maxx Metal Chassis Replacement: 8 단계, 이미지 1/2 Motorola Droid RAZR Maxx Metal Chassis Replacement: 8 단계, 이미지 2/2
    • Using the tip of the spudger, lift the red silicone cover off the battery terminal screws.
    • Remove the two 3.3mm T5 Torx battery terminal screws.
    • Grab the red battery removal tab and pull the battery out.
    • There might be some adhesive between the battery and motherboard assembly.
  9. Motorola Droid RAZR Maxx Metal Chassis Replacement: 9 단계, 이미지 1/2 Motorola Droid RAZR Maxx Metal Chassis Replacement: 9 단계, 이미지 2/2
    • Using the T5 bit pieces, remove the silver screws located around the metal chassis.
    • Remove the three 3.5 mm silver T5 screws that are located near the middle of the phone.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nick Kraese
회원 가입일: 10/08/14
657 평판
안내서 2개 작성하였습니다
USF Tampa, Team 14-6, Leahy Fall 2014 USF Tampa, Team 14-6, Leahy Fall 2014 회원
USFT-LEAHY-F14S14G6
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Where are the replacement chassis parts for this phone??? Thanks Joey K
sailorjt1985 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 1,736
