주요 콘텐츠로 건너뛰기
Motorola Droid RAZR Volume Rocker Replacement
필요한 것
  1. Motorola Droid RAZR Volume Rocker Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Motorola Droid RAZR Volume Rocker Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Volume Rocker Replacement: 2 단계, 이미지 3개 중 1개 Motorola Droid RAZR Volume Rocker Replacement: 2 단계, 이미지 3개 중 2개 Motorola Droid RAZR Volume Rocker Replacement: 2 단계, 이미지 3개 중 3개
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Volume Rocker Replacement: 3 단계, 이미지 3개 중 1개 Motorola Droid RAZR Volume Rocker Replacement: 3 단계, 이미지 3개 중 2개 Motorola Droid RAZR Volume Rocker Replacement: 3 단계, 이미지 3개 중 3개
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
  4. Motorola Droid RAZR Volume Rocker Replacement, Battery: 4 단계, 이미지 2개 중 1개 Motorola Droid RAZR Volume Rocker Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
  5. Motorola Droid RAZR Volume Rocker Replacement: 5 단계, 이미지 3개 중 1개 Motorola Droid RAZR Volume Rocker Replacement: 5 단계, 이미지 3개 중 2개 Motorola Droid RAZR Volume Rocker Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two 3.3 mm T5 Torx battery terminal screws.
    • Grab the blue battery removal tab and lift the battery out to remove it.
    • There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
    • Your phone will have a number of metal EMI shields on the motherboard, rather than the bare ICs seen here.
  6. Motorola Droid RAZR Volume Rocker Replacement, Camera Cover: 6 단계, 이미지 2개 중 1개 Motorola Droid RAZR Volume Rocker Replacement, Camera Cover: 6 단계, 이미지 2개 중 2개
    • Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
    • The following steps were performed without the use of a heat gun. Notice that the camera cover cracks very easily if you do not heat the adhesive that holds it in place.
    • Gently pry up the bottom edge of the camera cover with a plastic opening tool.
    • Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
    • Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
  7. Motorola Droid RAZR Volume Rocker Replacement: 7 단계, 이미지 3개 중 1개 Motorola Droid RAZR Volume Rocker Replacement: 7 단계, 이미지 3개 중 2개 Motorola Droid RAZR Volume Rocker Replacement: 7 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool underneath the top edge of the camera cover.
    • Gently pry the camera cover up as you slide the plastic opening tool across the top edge to free it from the adhesive.
    • Remove the camera cover.
  8. Motorola Droid RAZR Volume Rocker Replacement, Rear Case: 8 단계, 이미지 1개 중 1개
    • Remove the six screws securing the rear case to the rest of the phone:
    • three 6.7 mm silver T3 Torx screws at the top,
    • four 4.0 mm gold T3 Torx screws in the middle,
    • and three 4.5 mm black T5 Torx screws at the bottom.
  9. Motorola Droid RAZR Volume Rocker Replacement: 9 단계, 이미지 3개 중 1개 Motorola Droid RAZR Volume Rocker Replacement: 9 단계, 이미지 3개 중 2개 Motorola Droid RAZR Volume Rocker Replacement: 9 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool between the rear case and the motherboard assembly.
    • Work your way down the side of the phone and gently pry the rear case up.
    • Separate the rear case from the motherboard assembly.
  10. Motorola Droid RAZR Volume Rocker Replacement, Volume Rocker: 10 단계, 이미지 1개 중 1개
    • Remove the volume rocker from the rear panel.
    • Be sure to note how the volume rocker sat in the rear case to properly install your replacement.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
David Hodson
회원 가입일: 04/13/10
154,701 평판
안내서 127개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 6,964
