주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Droid Rear Case Replacement
필요한 것
  1. Motorola Droid Rear Case Replacement, Battery: 1 단계, 이미지 3개 중 1개 Motorola Droid Rear Case Replacement, Battery: 1 단계, 이미지 3개 중 2개 Motorola Droid Rear Case Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
    • Lift and remove the battery cover out from the phone.
  2. Motorola Droid Rear Case Replacement: 2 단계, 이미지 1개 중 1개
    • Grasp the upper left corner of the battery and lift it out of its housing.
  3. Motorola Droid Rear Case Replacement, Rear Case: 3 단계, 이미지 1개 중 1개
    • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
    • The cover is attached by adhesive, so some force may be required.
  4. Motorola Droid Rear Case Replacement: 4 단계, 이미지 2개 중 1개 Motorola Droid Rear Case Replacement: 4 단계, 이미지 2개 중 2개
    • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
    • Peel the ribbon up off the phone.
  5. Motorola Droid Rear Case Replacement: 5 단계, 이미지 2개 중 1개 Motorola Droid Rear Case Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully peel the device information label that covers the motherboard EMI shields.
    • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
  6. Motorola Droid Rear Case Replacement: 6 단계, 이미지 1개 중 1개
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  7. Motorola Droid Rear Case Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  8. Motorola Droid Rear Case Replacement: 8 단계, 이미지 1개 중 1개
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  9. Motorola Droid Rear Case Replacement: 9 단계, 이미지 1개 중 1개
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  10. Motorola Droid Rear Case Replacement: 10 단계, 이미지 2개 중 1개 Motorola Droid Rear Case Replacement: 10 단계, 이미지 2개 중 2개
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  11. Motorola Droid Rear Case Replacement: 11 단계, 이미지 2개 중 1개 Motorola Droid Rear Case Replacement: 11 단계, 이미지 2개 중 2개
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
131,576 평판
안내서 144개를 작성함
iFixit iFixit 회원
Staff
124 회원들
안내서 24,221개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 52
전체 시간: 40,989
