주요 콘텐츠로 건너뛰기
Motorola Droid Rear Case Replacement
필요한 것
  1. Motorola Droid Rear Case Replacement, Battery: 1 단계, 이미지 1/3 Motorola Droid Rear Case Replacement, Battery: 1 단계, 이미지 2/3 Motorola Droid Rear Case Replacement, Battery: 1 단계, 이미지 3/3
    • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
    • Lift and remove the battery cover out from the phone.
  2. Motorola Droid Rear Case Replacement: 2 단계, 이미지 1/1
    • Grasp the upper left corner of the battery and lift it out of its housing.
  3. Motorola Droid Rear Case Replacement, Rear Case: 3 단계, 이미지 1/1
    • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
    • The cover is attached by adhesive, so some force may be required.
  4. Motorola Droid Rear Case Replacement: 4 단계, 이미지 1/2 Motorola Droid Rear Case Replacement: 4 단계, 이미지 2/2
    • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
    • Peel the ribbon up off the phone.
  5. Motorola Droid Rear Case Replacement: 5 단계, 이미지 1/2 Motorola Droid Rear Case Replacement: 5 단계, 이미지 2/2
    • Carefully peel the device information label that covers the motherboard EMI shields.
    • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
  6. Motorola Droid Rear Case Replacement: 6 단계, 이미지 1/1
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  7. Motorola Droid Rear Case Replacement: 7 단계, 이미지 1/1
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  8. Motorola Droid Rear Case Replacement: 8 단계, 이미지 1/1
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  9. Motorola Droid Rear Case Replacement: 9 단계, 이미지 1/1
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  10. Motorola Droid Rear Case Replacement: 10 단계, 이미지 1/2 Motorola Droid Rear Case Replacement: 10 단계, 이미지 2/2
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  11. Motorola Droid Rear Case Replacement: 11 단계, 이미지 1/2 Motorola Droid Rear Case Replacement: 11 단계, 이미지 2/2
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Brett Hartt
회원 가입일: 04/12/10
125,688 평판
안내서 143개 작성하였습니다
iFixit iFixit 회원
Community
137 회원들
안내서 17,047개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 40,665
