소개
This guide will take you through the delicate process of removing the rear panel of the Motorola Droid.
필요한 것
Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
Lift and remove the battery cover out from the phone.
Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
This is actually extremely difficult to do with the plastic spudger pictured. I was forced to use the thin sharp tip on a metal spudger to get any leverage, which slightly damages the plastic.
다른 6명이 해당 안내서를 완성하였습니다.
