소개
This guide will take you though the process of replacing a faulty or non-functioning speaker in your Motorola Droid.
도구
부품
지정된 부품이 없습니다.
Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
Lift and remove the battery cover out from the phone.
Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
다른 2명이 해당 안내서를 완성하였습니다.
