이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will take you though the process of replacing a faulty or non-functioning speaker in your Motorola Droid.
필요한 것
Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
Lift and remove the battery cover out from the phone.
Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
다른 2명이 해당 안내서를 완성하였습니다.
