주요 콘텐츠로 건너뛰기
Motorola Droid Turbo Dual LED Flash Board Replacement
필요한 것
  1. Motorola Droid Turbo Dual LED Flash Board Replacement, Rear Case: 1 단계, 이미지 1/1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Dual LED Flash Board Replacement: 2 단계, 이미지 1/2 Motorola Droid Turbo Dual LED Flash Board Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: 3 단계, 이미지 1/2 Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: 3 단계, 이미지 2/2
    • Use a Jimmy to separate the dual LED flash board from the rear case.
    • The board is secured with some light adhesive, so some force may be required.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Geoff Wacker
회원 가입일: 09/30/13
89,898 평판
안내서 89개 작성하였습니다
댓글 한 개
Gostaria se possível alguem tenha o manual de serviço do Moto maxx XT 1225 ou 1254. Porf favor , ddani8260@gmail.com
Daniel Gomes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 959
