주요 콘텐츠로 건너뛰기
Motorola Droid Turbo Earpiece Speaker Replacement
필요한 것
  1. Motorola Droid Turbo Earpiece Speaker Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Earpiece Speaker Replacement: 2 단계, 이미지 2개 중 1개 Motorola Droid Turbo Earpiece Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Earpiece Speaker Replacement, Midframe: 3 단계, 이미지 1개 중 1개
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Earpiece Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Earpiece Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the midframe.
  6. Motorola Droid Turbo Earpiece Speaker Replacement, Earpiece Speaker: 6 단계, 이미지 2개 중 1개 Motorola Droid Turbo Earpiece Speaker Replacement, Earpiece Speaker: 6 단계, 이미지 2개 중 2개
    • Use a Jimmy to pry under the speaker and lift to remove it.
    • Be sure to place your tool under the entire speaker assembly, against the plastic frame, and pry there.
    • These photos show an incorrect tool position—prying this high up on the speaker assembly may damage it. Place your tool underneath the speaker assembly, not on the edge as shown here.
    • The speaker is secured with some light adhesive, so some force may be required.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Geoff Wacker
회원 가입일: 09/30/13
92,071 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 7,190
