주요 콘텐츠로 건너뛰기
Motorola Droid Turbo Midframe Replacement
필요한 것
  1. Motorola Droid Turbo Midframe Replacement, Rear Case: 1 단계, 이미지 1/1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Midframe Replacement: 2 단계, 이미지 1/2 Motorola Droid Turbo Midframe Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Midframe Replacement, Midframe: 3 단계, 이미지 1/1
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Midframe Replacement: 4 단계, 이미지 1/1
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Midframe Replacement: 5 단계, 이미지 1/1
    • Remove the midframe.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Geoff Wacker
회원 가입일: 09/30/13
87,874 평판
안내서 89개 작성하였습니다
One Comment
Which circuits depend of the midframe?
gabriel.mourasant - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,130
