주요 콘텐츠로 건너뛰기
Motorola Droid Turbo Vibrator Replacement
필요한 것
  1. Motorola Droid Turbo Vibrator Replacement, Rear Case: 1 단계, 이미지 1/1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Vibrator Replacement: 2 단계, 이미지 1/2 Motorola Droid Turbo Vibrator Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Vibrator Replacement, Midframe: 3 단계, 이미지 1/1
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Vibrator Replacement: 4 단계, 이미지 1/1
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Vibrator Replacement: 5 단계, 이미지 1/1
    • Remove the midframe.
  6. Motorola Droid Turbo Vibrator Replacement, Vibrator: 6 단계, 이미지 1/2 Motorola Droid Turbo Vibrator Replacement, Vibrator: 6 단계, 이미지 2/2
    • Use the pointed end of a spudger to gently pry the vibrator up and away from the midframe.
결론
Geoff Wacker
회원 가입일: 09/30/13
87,877 평판
안내서 89개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,176
