주요 콘텐츠로 건너뛰기
Motorola Droid X Battery Replacement
  1. Motorola Droid X Battery Replacement, Battery: 1 단계, 이미지 1/2 Motorola Droid X Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
  2. Motorola Droid X Battery Replacement: 2 단계, 이미지 1/2 Motorola Droid X Battery Replacement: 2 단계, 이미지 2/2
    • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
  3. Motorola Droid X Battery Replacement: 3 단계, 이미지 1/2 Motorola Droid X Battery Replacement: 3 단계, 이미지 2/2
    • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
  4. Motorola Droid X Battery Replacement: 4 단계, 이미지 1/2 Motorola Droid X Battery Replacement: 4 단계, 이미지 2/2
    • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
  5. Motorola Droid X Battery Replacement: 5 단계, 이미지 1/1
    • The battery has been successfully removed.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Alfred Rosen
회원 가입일: 10/04/12
117 평판
안내서 1개 작성함
Cal Poly, Team 18-40, Regan Fall 2012 Cal Poly, Team 18-40, Regan Fall 2012 회원
CPSU-REGAN-F12S18G40
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 8
30일 전: 11
전체 시간: 3,954
