부품
부품은 필요하지 않습니다.
Objective: remove the rear case from the Motorola Droid X phone.
  • Objective: remove the rear case from the Motorola Droid X phone.
    • This is what the Motorola Droid X looks like before disassembly. In the front, there is a large LCD touch screen.
댓글 쓰기
INSTRUCTION: Turn the phone over so that the back faces up.
  • INSTRUCTION: Turn the phone over so that the back faces up.
댓글 쓰기
Objective: remove the battery casing plate.
  • Objective: remove the battery casing plate.
    • The case plate has a push and slide mechanism.
댓글 쓰기
INSTRUCTION 1: Push on the upper side of the casing located under the camera lens.
  • INSTRUCTION 1: Push on the upper side of the casing located under the camera lens.
  • INSTRUCTION 2: Slide down the battery case plate.
댓글 쓰기
INSTRUCTION: Insert your finger tips into the edges of the opening and pull the casing off.
  • INSTRUCTION: Insert your finger tips into the edges of the opening and pull the casing off.
댓글 쓰기
Objective: remove the battery from the battery compartment.
  • Objective: remove the battery from the battery compartment.
댓글 쓰기
INSTRUCTION: Grab the red tab that says "Battery Release" and slowly lift it up. This will remove the battery.
  • INSTRUCTION: Grab the red tab that says "Battery Release" and slowly lift it up. This will remove the battery.
댓글 쓰기
Objective:  remove two small black screws from the back of the phone.
  • Objective: remove two small black screws from the back of the phone.
    • These two (2) screws help hold the phone together. They need to be removed by a Phillips Hex 2mm screwdriver,
댓글 쓰기
INSTRUCTION: Remove two black screws from the back of the phone.
  • INSTRUCTION: Remove two black screws from the back of the phone.
댓글 쓰기
Objective: remove the two plastic pieces in front of the phone - they cover the remaining screws.
  • Objective: remove the two plastic pieces in front of the phone - they cover the remaining screws.
    • The two plastic pieces are clipped onto the phone as covers. They are located at the top and the bottom of the phone.
댓글 쓰기
INSTRUCTION: Flip the phone over to the front side.
  • INSTRUCTION: Flip the phone over to the front side.
댓글 쓰기
INSTRUCTION: Use the iFixit tool as a crowbar to pry the top plastic cover piece off of the phone.  It will pop off.
  • INSTRUCTION: Use the iFixit tool as a crowbar to pry the top plastic cover piece off of the phone. It will pop off.
댓글 쓰기
INSTRUCTION: Use the iFixit tool as a crowbar to pry the bottom plastic piece off the phone.
  • INSTRUCTION: Use the iFixit tool as a crowbar to pry the bottom plastic piece off the phone.
댓글 쓰기
Objective: remove four white screws from the corners of the screen.
  • Objective: remove four white screws from the corners of the screen.
    • These four (4) screws help hold the phone together. Use a Phillips Hex 2mm screwdriver
댓글 쓰기
INSTRUCTION: remove the 2 white screws from the upper corners of the screen.
  • INSTRUCTION: remove the 2 white screws from the upper corners of the screen.
댓글 쓰기
INSTRUCTION: remove the 2 white screws from the lower corners of the screen.
  • INSTRUCTION: remove the 2 white screws from the lower corners of the screen.
댓글 쓰기
Objective: remove the rear case from the phone in order to provide access to inside the phone.
  • Objective: remove the rear case from the phone in order to provide access to inside the phone.
    • The phone is now held together by the casing alone. You need to pop the two halves apart.
댓글 쓰기
INSTRUCTION: Use the iFixit tool like a crowbar to pry apart the front and rear halves of the  casing. They will pop apart.
  • INSTRUCTION: Use the iFixit tool like a crowbar to pry apart the front and rear halves of the casing. They will pop apart.
댓글 쓰기
Now you are ready to access the internal circuits of the phone.
  • Now you are ready to access the internal circuits of the phone.
댓글 쓰기
The objective of the guide is to remove the motherboard from the camera. The mother board is an  L-shaped green circuit board.
  • The objective of the guide is to remove the motherboard from the camera.
    • The mother board is an L-shaped green circuit board.
댓글 쓰기
In order to start, the rear case should have been removed. Follow the rear case removal guide for that procedure.
  • In order to start, the rear case should have been removed. Follow the rear case removal guide for that procedure.
댓글 쓰기
Let's start. The objective of the following two steps is  to remove the circuit connectors connected to the mother board.
  • Let's start. The objective of the following two steps is to remove the circuit connectors connected to the mother board.
    • They are "clip-on" type connectors which have a black leathery coating. The connectors are located at the lower bottom left part of the "L-Shaped" motherboard.
    • There are two connectors with the larger one overlapping the smaller one. You can disconnect them either by hand or with the iFixit tool.
댓글 쓰기
INSTRUCTION: Disconnect the larger connector on the top by pulling on the edge of the black coated connector. It will pop off.
  • INSTRUCTION: Disconnect the larger connector on the top by pulling on the edge of the black coated connector. It will pop off.
댓글 쓰기
INSTRUCTION: The smaller connector will become visible once the larger one is disconnected. Disconnect it also the same way as before. INSTRUCTION: The smaller connector will become visible once the larger one is disconnected. Disconnect it also the same way as before.
  • INSTRUCTION: The smaller connector will become visible once the larger one is disconnected. Disconnect it also the same way as before.
댓글 쓰기
Objective: disconnect the white wire connected to the motherboard. The wire is visible at the upper left of the "L-shaped" Motherboard. Each end of the white wire is connected by a circular pop-on connector.
  • Objective: disconnect the white wire connected to the motherboard.
    • The wire is visible at the upper left of the "L-shaped" Motherboard. Each end of the white wire is connected by a circular pop-on connector.
댓글 쓰기
INSTRUCTION: Grab and pull up on the silver connector that is at the end of the white wire connected to the motherboard until it pops off.
  • INSTRUCTION: Grab and pull up on the silver connector that is at the end of the white wire connected to the motherboard until it pops off.
댓글 쓰기
Objective: separate the motherboard from the rest of the phone.
  • Objective: separate the motherboard from the rest of the phone.
    • The motherboard is held in place by two silver clasps on the left side of the phone.
댓글 쓰기
INSTRUCTION: Use the iFixit tool to pry the clasps open. This will free the motherboard from the case.
  • INSTRUCTION: Use the iFixit tool to pry the clasps open. This will free the motherboard from the case.
댓글 쓰기
Objective: detach the camera component from the phone.
  • Objective: detach the camera component from the phone.
    • The camera component is located at the upper left part of the phone, right above the white wire mentioned previously. The camera is square.
댓글 쓰기
INSTRUCTION: Grab the camera component and pull it  out of its casing. Keep the camera connected to the mother board.
  • INSTRUCTION: Grab the camera component and pull it out of its casing. Keep the camera connected to the mother board.
댓글 쓰기
Objective:  disconnect a circuit connector from underneath the motherboard to finish the process.
  • Objective: disconnect a circuit connector from underneath the motherboard to finish the process.
    • The circuit connector is a gold and black colored "clip-on" type connector located in the middle left side of the phone. It is connected to the underside of the motherboard.
댓글 쓰기
INSTRUCTION: Slowly lift up the motherboard as you would turn a page.
  • INSTRUCTION: Slowly lift up the motherboard as you would turn a page.
    • The motherboard is still connected to the phone.'''
댓글 쓰기
INSTRUCTION: Use your fingertips to grab  a edge of the connector and pop it off.
  • INSTRUCTION: Use your fingertips to grab a edge of the connector and pop it off.
댓글 쓰기
Conclusion: Now, you have successfully removed the motherboard.
  • Conclusion: Now, you have successfully removed the motherboard.
  • At this point, you will be left with the following: 2 black screws, 4 silver screws, 1 motherboard, 1 camera, 1 rear case, 1 battery, 2 plastic pieces from the front case, and the rest of the phone.
댓글 쓰기
The objective of the guide is to replace the camera component on the motherboard.
  • The objective of the guide is to replace the camera component on the motherboard.
댓글 쓰기
In order to start, the motherboard should have been separated from the rest of the phone.
  • In order to start, the motherboard should have been separated from the rest of the phone.
    • Follow the motherboard removal guide for that procedure.
댓글 쓰기
Objective: separate the existing camera component from the motherboard.
  • Objective: separate the existing camera component from the motherboard.
    • The camera component is connected to the rear side of the top left of the motherboard. The connector is a black colored tab which is a pop on type mechanism.
댓글 쓰기
    • It is up side up is when it looks like the capital letter L.
댓글 쓰기
INSTRUCTION: Have the motherboard upside down.
  • INSTRUCTION: Have the motherboard upside down.
댓글 쓰기
INSTRUCTION: Flip over the golden circuit   tab .
  • INSTRUCTION: Flip over the golden circuit tab .
댓글 쓰기
INSTRUCTION: Pull on the edges of the black connector tab and pop it off.
  • INSTRUCTION: Pull on the edges of the black connector tab and pop it off.
댓글 쓰기
OBJECTIVE: Attach the replacement camera component to the motherboard.
  • OBJECTIVE: Attach the replacement camera component to the motherboard.
댓글 쓰기
INSTRUCTION: Pop on black connector tab of the new component at the same place where the existing one was removed.
  • INSTRUCTION: Pop on black connector tab of the new component at the same place where the existing one was removed.
댓글 쓰기
Conclusion: You have finished replacing the camera component of your phone.
  • Conclusion: You have finished replacing the camera component of your phone.
댓글 쓰기
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Gage
회원 가입일: 2012년 09월 27일
1 평판
안내서 1개 작성함
Ohio State, Team 1-1, Buehl Fall 2012 Ohio State, Team 1-1, Buehl Fall 2012 회원
OSU-BUEHL-F12S1G1
4 회원들
안내서 3개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 634
