부품
부품은 필요하지 않습니다.
Follow removal of rear housing guide. This should be your starting point.
  • Follow removal of rear housing guide. This should be your starting point.
댓글 쓰기
Using your fingernail or an opening tool, peel back the first layer of tape, located toward the left side of the phone. The circuit wiring should peel away with the tape. If not, remove the circuit wiring from the terminal.
  • Using your fingernail or an opening tool, peel back the first layer of tape, located toward the left side of the phone. The circuit wiring should peel away with the tape. If not, remove the circuit wiring from the terminal.
댓글 쓰기
Peel away second layer of tape and smaller circuit wiring.
  • Peel away second layer of tape and smaller circuit wiring.
  • Use caution as this wiring is extremely fragile.
댓글 쓰기
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Using tweezers, remove wire connecting motherboard to small circuitboard at the bottom right of camera housing. Remove each head of the wire individually. Using tweezers, remove wire connecting motherboard to small circuitboard at the bottom right of camera housing. Remove each head of the wire individually.
  • Using tweezers, remove wire connecting motherboard to small circuitboard at the bottom right of camera housing. Remove each head of the wire individually.
댓글 쓰기
Pry up motherboard using opening tool to pry circuitboard away from two clasps on the left side of phone.
  • Pry up motherboard using opening tool to pry circuitboard away from two clasps on the left side of phone.
댓글 쓰기
Pull camera up from rear housing of phone using fingers.
  • Pull camera up from rear housing of phone using fingers.
댓글 쓰기
Remove final circuit from terminal on the bottom side of the motherboard using the opening tool.
  • Remove final circuit from terminal on the bottom side of the motherboard using the opening tool.
댓글 쓰기
Completed.
  • Completed.
댓글 쓰기
결론
Genevieve Abbiss
회원 가입일: 2012년 09월 27일
19 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-1, Buehl Fall 2012 Ohio State, Team 1-1, Buehl Fall 2012 회원
OSU-BUEHL-F12S1G1
4 회원들
안내서 3개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,223
