이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Objective: remove the rear case from the Motorola Droid X phone.
This is what the Motorola Droid X looks like before disassembly. In the front, there is a large LCD touch screen.
Objective: remove the battery casing plate.
The case plate has a push and slide mechanism.
INSTRUCTION 1: Push on the upper side of the casing located under the camera lens.
INSTRUCTION 2: Slide down the battery case plate.
INSTRUCTION: Insert your finger tips into the edges of the opening and pull the casing off.
INSTRUCTION: Grab the red tab that says "Battery Release" and slowly lift it up. This will remove the battery.
Objective: remove the two plastic pieces in front of the phone - they cover the remaining screws.
INSTRUCTION: Use the iFixit tool as a crowbar to pry the top plastic cover piece off of the phone. It will pop off.
INSTRUCTION: Use the iFixit tool as a crowbar to pry the bottom plastic piece off the phone.
INSTRUCTION: remove the 2 white screws from the upper corners of the screen.
INSTRUCTION: remove the 2 white screws from the lower corners of the screen.
Objective: remove the rear case from the phone in order to provide access to inside the phone.
The phone is now held together by the casing alone. You need to pop the two halves apart.
INSTRUCTION: Use the iFixit tool like a crowbar to pry apart the front and rear halves of the casing. They will pop apart.
다른 2명이 해당 안내서를 완성하였습니다.
