주요 콘텐츠로 건너뛰기
Motorola Droid X Rear Housing Replacement
필요한 것
  1. Motorola Droid X Rear Housing Replacement, Rear Housing: 1 단계, 이미지 1개 중 1개
    • First begin by sliding down the battery door, and place that to the side.
  2. Motorola Droid X Rear Housing Replacement: 2 단계, 이미지 2개 중 1개 Motorola Droid X Rear Housing Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the battery tab up, and remove the battery from the phone.
  3. Motorola Droid X Rear Housing Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two T5 screws as shown by the markers.
  4. Motorola Droid X Rear Housing Replacement: 4 단계, 이미지 2개 중 1개 Motorola Droid X Rear Housing Replacement: 4 단계, 이미지 2개 중 2개
    • Flip the phone over to the front, and slide an opening tool as shown between the metal housing & the plastic piece covering the lower portion of the phone by the microphone.
  5. Motorola Droid X Rear Housing Replacement: 5 단계, 이미지 1개 중 1개
    • Now do the same to the top of the phone with your opening tool as shown to remove the other plastic piece covering the top of the phone.
  6. Motorola Droid X Rear Housing Replacement: 6 단계, 이미지 2개 중 1개 Motorola Droid X Rear Housing Replacement: 6 단계, 이미지 2개 중 2개
    • Now with both of the plastic covers removed, remove the 4 silver T5 screws on the top and bottom of the unit as shown.
  7. Motorola Droid X Rear Housing Replacement: 7 단계, 이미지 3개 중 1개 Motorola Droid X Rear Housing Replacement: 7 단계, 이미지 3개 중 2개 Motorola Droid X Rear Housing Replacement: 7 단계, 이미지 3개 중 3개
    • Starting on the top right side of the phone, run your opening tool down the side and all the way around with slight force to begin to separate the back housing from the front assembly.
    • Look at the two pictures showing the clips to help you know where they are located.
  8. Motorola Droid X Rear Housing Replacement: 8 단계, 이미지 1개 중 1개
    • You can easily release the two clips on the right side (nearest the headphone jack) by pressing in the black plastic tabs inside the metal clips. The torx screwdriver you used earlier works well for this.
  9. Motorola Droid X Rear Housing Replacement: 9 단계, 이미지 1개 중 1개
    • Congratulations! You have now successfully removed your back housing from your Droid X!
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Josh Forester
회원 가입일: 11/28/10
2,558 평판
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 5,615
