주요 콘텐츠로 건너뛰기
Motorola Droid X2 Motherboard Replacement
필요한 것
  1. Motorola Droid X2 Motherboard Replacement, Battery: 1 단계, 이미지 1/3 Motorola Droid X2 Motherboard Replacement, Battery: 1 단계, 이미지 2/3 Motorola Droid X2 Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Slide the plastic case off of the back of the phone, exposing the battery.
  2. Motorola Droid X2 Motherboard Replacement: 2 단계, 이미지 1/3 Motorola Droid X2 Motherboard Replacement: 2 단계, 이미지 2/3 Motorola Droid X2 Motherboard Replacement: 2 단계, 이미지 3/3
    • Pull up on the red battery release tab and pull the battery out of the phone.
  3. Motorola Droid X2 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/2 Motorola Droid X2 Motherboard Replacement, Motherboard: 3 단계, 이미지 2/2
    • Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
    • Be careful to not strip any screws.
  4. Motorola Droid X2 Motherboard Replacement: 4 단계, 이미지 1/3 Motorola Droid X2 Motherboard Replacement: 4 단계, 이미지 2/3 Motorola Droid X2 Motherboard Replacement: 4 단계, 이미지 3/3
    • Using a prying tool, snap off the front casing on the top and bottom of the phone.
    • Be careful not to lose the small rubber piece that sits over the microphone.
  5. Motorola Droid X2 Motherboard Replacement: 5 단계, 이미지 1/2 Motorola Droid X2 Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
  6. Motorola Droid X2 Motherboard Replacement: 6 단계, 이미지 1/3 Motorola Droid X2 Motherboard Replacement: 6 단계, 이미지 2/3 Motorola Droid X2 Motherboard Replacement: 6 단계, 이미지 3/3
    • Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
  7. Motorola Droid X2 Motherboard Replacement: 7 단계, 이미지 1/3 Motorola Droid X2 Motherboard Replacement: 7 단계, 이미지 2/3 Motorola Droid X2 Motherboard Replacement: 7 단계, 이미지 3/3
    • Using tweezers, remove the white wire at the top of the phone near the camera.
  8. Motorola Droid X2 Motherboard Replacement: 8 단계, 이미지 1/2 Motorola Droid X2 Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove these nine screws using a T-3 torques. These screws should be 2.40 mm in length
  9. Motorola Droid X2 Motherboard Replacement: 9 단계, 이미지 1/2 Motorola Droid X2 Motherboard Replacement: 9 단계, 이미지 2/2
    • Using tweezers, removed the white electrical tape on the motherboard.
  10. Motorola Droid X2 Motherboard Replacement: 10 단계, 이미지 1/2 Motorola Droid X2 Motherboard Replacement: 10 단계, 이미지 2/2
    • Using the plastic opening tool, lift up to remove the connector.
  11. Motorola Droid X2 Motherboard Replacement: 11 단계, 이미지 1/2 Motorola Droid X2 Motherboard Replacement: 11 단계, 이미지 2/2
    • Using a pry tool, lift the jawbone connector.
  12. Motorola Droid X2 Motherboard Replacement: 12 단계, 이미지 1/2 Motorola Droid X2 Motherboard Replacement: 12 단계, 이미지 2/2
    • Using tweezers, carefully disconnect the cable connector by pulling the cable out.
  13. Motorola Droid X2 Motherboard Replacement: 13 단계, 이미지 1/3 Motorola Droid X2 Motherboard Replacement: 13 단계, 이미지 2/3 Motorola Droid X2 Motherboard Replacement: 13 단계, 이미지 3/3
    • Use a spudger to disconnect the cable connector.
  14. Motorola Droid X2 Motherboard Replacement: 14 단계, 이미지 1/3 Motorola Droid X2 Motherboard Replacement: 14 단계, 이미지 2/3 Motorola Droid X2 Motherboard Replacement: 14 단계, 이미지 3/3
    • Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Aaron Mak
회원 가입일: 10/29/14
658 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 4-3, Miles Fall 2014 UMass Dartmouth, Team 4-3, Miles Fall 2014 회원
UMASSD-MILES-F14S4G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 23
전체 시간: 779
