주요 콘텐츠로 건너뛰기
Motorola Droid X2 Rear Facing Camera Replacement
필요한 것
  1. Motorola Droid X2 Rear Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 2개 Motorola Droid X2 Rear Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Slide the plastic case off of the back of the phone, exposing the battery.
  2. Motorola Droid X2 Rear Facing Camera Replacement: 2 단계, 이미지 3개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement: 2 단계, 이미지 3개 중 2개 Motorola Droid X2 Rear Facing Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Pull up on the red battery release tab and pull the battery out of the phone.
  3. Motorola Droid X2 Rear Facing Camera Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
    • Be careful to not strip any screws.
  4. Motorola Droid X2 Rear Facing Camera Replacement: 4 단계, 이미지 3개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement: 4 단계, 이미지 3개 중 2개 Motorola Droid X2 Rear Facing Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Using a prying tool, snap off the front casing on the top and bottom of the phone.
    • Be careful not to lose the small rubber piece that sits over the microphone.
  5. Motorola Droid X2 Rear Facing Camera Replacement: 5 단계, 이미지 2개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
  6. Motorola Droid X2 Rear Facing Camera Replacement: 6 단계, 이미지 3개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement: 6 단계, 이미지 3개 중 2개 Motorola Droid X2 Rear Facing Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
  7. Motorola Droid X2 Rear Facing Camera Replacement: 7 단계, 이미지 3개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement: 7 단계, 이미지 3개 중 2개 Motorola Droid X2 Rear Facing Camera Replacement: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using tweezers, remove the white wire at the top of the phone near the camera.
  8. Motorola Droid X2 Rear Facing Camera Replacement: 8 단계, 이미지 2개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement: 8 단계, 이미지 2개 중 2개
    • Remove these nine screws using a T-3 torques. These screws should be 2.40 mm in length
  9. Motorola Droid X2 Rear Facing Camera Replacement: 9 단계, 이미지 2개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement: 9 단계, 이미지 2개 중 2개
    • Using tweezers, removed the white electrical tape on the motherboard.
  10. Motorola Droid X2 Rear Facing Camera Replacement: 10 단계, 이미지 2개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement: 10 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, lift up to remove the connector.
  11. Motorola Droid X2 Rear Facing Camera Replacement: 11 단계, 이미지 2개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement: 11 단계, 이미지 2개 중 2개
    • Using a pry tool, lift the jawbone connector.
  12. Motorola Droid X2 Rear Facing Camera Replacement: 12 단계, 이미지 2개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement: 12 단계, 이미지 2개 중 2개
    • Using tweezers, carefully disconnect the cable connector by pulling the cable out.
  13. Motorola Droid X2 Rear Facing Camera Replacement: 13 단계, 이미지 3개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement: 13 단계, 이미지 3개 중 2개 Motorola Droid X2 Rear Facing Camera Replacement: 13 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the cable connector.
  14. Motorola Droid X2 Rear Facing Camera Replacement: 14 단계, 이미지 3개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement: 14 단계, 이미지 3개 중 2개 Motorola Droid X2 Rear Facing Camera Replacement: 14 단계, 이미지 3개 중 3개
    • Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
  15. Motorola Droid X2 Rear Facing Camera Replacement, Rear Facing Camera: 15 단계, 이미지 3개 중 1개 Motorola Droid X2 Rear Facing Camera Replacement, Rear Facing Camera: 15 단계, 이미지 3개 중 2개 Motorola Droid X2 Rear Facing Camera Replacement, Rear Facing Camera: 15 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • There should be jawbone connector here. However it was broken on this particular device. Lift it up using a pry tool.
    • Using tweezers, remove cable from motherboard.
결론
작성자
3다른 기여자 명과 함께
Aaron Mak
회원 가입일: 10/29/14
658 평판
안내서 4개를 작성함
UMass Dartmouth, Team 4-3, Miles Fall 2014 UMass Dartmouth, Team 4-3, Miles Fall 2014 회원
UMASSD-MILES-F14S4G3
3 회원들
안내서 8개를 작성함
1가이드 댓글
how do u get it back on when it dose not come back on
brianna
Brianna Dittbrenner - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 415
