주요 콘텐츠로 건너뛰기
Motorola Droid X2 Screen Replacement
필요한 것
  1. Motorola Droid X2 Screen Replacement, Battery: 1 단계, 이미지 1/3 Motorola Droid X2 Screen Replacement, Battery: 1 단계, 이미지 2/3 Motorola Droid X2 Screen Replacement, Battery: 1 단계, 이미지 3/3
    • Slide the plastic case off of the back of the phone, exposing the battery.
  2. Motorola Droid X2 Screen Replacement: 2 단계, 이미지 1/3 Motorola Droid X2 Screen Replacement: 2 단계, 이미지 2/3 Motorola Droid X2 Screen Replacement: 2 단계, 이미지 3/3
    • Pull up on the red battery release tab and pull the battery out of the phone.
  3. Motorola Droid X2 Screen Replacement, Motherboard: 3 단계, 이미지 1/2 Motorola Droid X2 Screen Replacement, Motherboard: 3 단계, 이미지 2/2
    • Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
    • Be careful to not strip any screws.
  4. Motorola Droid X2 Screen Replacement: 4 단계, 이미지 1/3 Motorola Droid X2 Screen Replacement: 4 단계, 이미지 2/3 Motorola Droid X2 Screen Replacement: 4 단계, 이미지 3/3
    • Using a prying tool, snap off the front casing on the top and bottom of the phone.
    • Be careful not to lose the small rubber piece that sits over the microphone.
  5. Motorola Droid X2 Screen Replacement: 5 단계, 이미지 1/2 Motorola Droid X2 Screen Replacement: 5 단계, 이미지 2/2
    • Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
  6. Motorola Droid X2 Screen Replacement: 6 단계, 이미지 1/3 Motorola Droid X2 Screen Replacement: 6 단계, 이미지 2/3 Motorola Droid X2 Screen Replacement: 6 단계, 이미지 3/3
    • Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
  7. Motorola Droid X2 Screen Replacement: 7 단계, 이미지 1/3 Motorola Droid X2 Screen Replacement: 7 단계, 이미지 2/3 Motorola Droid X2 Screen Replacement: 7 단계, 이미지 3/3
    • Using tweezers, remove the white wire at the top of the phone near the camera.
  8. Motorola Droid X2 Screen Replacement: 8 단계, 이미지 1/2 Motorola Droid X2 Screen Replacement: 8 단계, 이미지 2/2
    • Remove these nine screws using a T-3 torques. These screws should be 2.40 mm in length
  9. Motorola Droid X2 Screen Replacement: 9 단계, 이미지 1/2 Motorola Droid X2 Screen Replacement: 9 단계, 이미지 2/2
    • Using tweezers, removed the white electrical tape on the motherboard.
  10. Motorola Droid X2 Screen Replacement: 10 단계, 이미지 1/2 Motorola Droid X2 Screen Replacement: 10 단계, 이미지 2/2
    • Using the plastic opening tool, lift up to remove the connector.
  11. Motorola Droid X2 Screen Replacement: 11 단계, 이미지 1/2 Motorola Droid X2 Screen Replacement: 11 단계, 이미지 2/2
    • Using a pry tool, lift the jawbone connector.
  12. Motorola Droid X2 Screen Replacement: 12 단계, 이미지 1/2 Motorola Droid X2 Screen Replacement: 12 단계, 이미지 2/2
    • Using tweezers, carefully disconnect the cable connector by pulling the cable out.
  13. Motorola Droid X2 Screen Replacement: 13 단계, 이미지 1/3 Motorola Droid X2 Screen Replacement: 13 단계, 이미지 2/3 Motorola Droid X2 Screen Replacement: 13 단계, 이미지 3/3
    • Use a spudger to disconnect the cable connector.
  14. Motorola Droid X2 Screen Replacement: 14 단계, 이미지 1/3 Motorola Droid X2 Screen Replacement: 14 단계, 이미지 2/3 Motorola Droid X2 Screen Replacement: 14 단계, 이미지 3/3
    • Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
  15. Motorola Droid X2 Screen Replacement, Screen: 15 단계, 이미지 1/2 Motorola Droid X2 Screen Replacement, Screen: 15 단계, 이미지 2/2
    • Remove the 4 screws using a T-3 torques.. These screws are 2.40 mm in length.
    • Be careful to not strip the screws.
  16. Motorola Droid X2 Screen Replacement: 16 단계, 이미지 1/3 Motorola Droid X2 Screen Replacement: 16 단계, 이미지 2/3 Motorola Droid X2 Screen Replacement: 16 단계, 이미지 3/3
    • Using tweezers, remove the white tape to reveal the connector
  17. Motorola Droid X2 Screen Replacement: 17 단계, 이미지 1/1
    • Using the plastic opening tool, lift the jawbone connector.
  18. Motorola Droid X2 Screen Replacement: 18 단계, 이미지 1/2 Motorola Droid X2 Screen Replacement: 18 단계, 이미지 2/2
    • Using tweezers, remove cable from the connector
  19. Motorola Droid X2 Screen Replacement: 19 단계, 이미지 1/3 Motorola Droid X2 Screen Replacement: 19 단계, 이미지 2/3 Motorola Droid X2 Screen Replacement: 19 단계, 이미지 3/3
    • Using a plastic opening tool, lift the connector from the device
  20. Motorola Droid X2 Screen Replacement: 20 단계, 이미지 1/3 Motorola Droid X2 Screen Replacement: 20 단계, 이미지 2/3 Motorola Droid X2 Screen Replacement: 20 단계, 이미지 3/3
    • Lift the ribbon from the device
    • This does require some effort to remove.
  21. Motorola Droid X2 Screen Replacement: 21 단계, 이미지 1/3 Motorola Droid X2 Screen Replacement: 21 단계, 이미지 2/3 Motorola Droid X2 Screen Replacement: 21 단계, 이미지 3/3
    • Lift the screen off of the device
  22. Motorola Droid X2 Screen Replacement: 22 단계, 이미지 1/2 Motorola Droid X2 Screen Replacement: 22 단계, 이미지 2/2
    • Using a heat gun, gently heat the edges of the screen
    • Be careful as overheating can damage the electronics.
    • The screen will be hot after.
  23. Motorola Droid X2 Screen Replacement: 23 단계, 이미지 1/3 Motorola Droid X2 Screen Replacement: 23 단계, 이미지 2/3 Motorola Droid X2 Screen Replacement: 23 단계, 이미지 3/3
    • Lift the screen from the frame.
결론
Aaron Mak
회원 가입일: 10/29/14
658 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 4-3, Miles Fall 2014 UMass Dartmouth, Team 4-3, Miles Fall 2014 회원
UMASSD-MILES-F14S4G3
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
I recently ran into an interesting situation with the Droid X2 at my repair shop. I know this is an older device, but this is still a very important piece of information: there are 2 different types of digitizers and 2 different types of LCD's, depending on the Droid X2's transceiver number. Type A digitizer has a smaller front row button connector, Type B is larger. Same with the LCD, there is a Type A small connector and a Type B larger connector. Under the battery on the barcode sticker, right below the "MB870" barcode is the transceiver number, starting with "SJUG" and ending in either 6250 (type A) or 6065 (type B). Anyone buying a replacement LCD or digitizer needs to know which one to get, or else the connectors won't fit.
Andrew F - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 1,037
