소개
If the buttons on your Motorola E815 are unresponsive or do not seem as crisp as they used to be, you may need to replace your keypad. To accomplish this, you will
- Dissemble the phone
- Access the keypad for repair or replacement
부품
지정된 부품이 없습니다.
Locate the two screws on the backside of the phone.
Unscrew the two screws using a T6 Screwdriver.
Gently pull the top section of the phone upwards until you feel some resistance.
Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
Using tweezers, gently pry the connector from the circuit board.
Carefully detach the two sections of the phone.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
We should have a motherboard replacement.
Santi12008 - 답글
We need to fullify more this content.
Santi12008 - 답글
